P261B just came up but still drives
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kobear18, Jul 20, 2020.
Tags:
  1. kobear18
    kobear18 Junior Member
    92
    23
    san francisco
    Not sure if this is temporary or the water pump is done? I got Torque pro to check it and the code P261B came up for water pump problem. However, the 2010 Prius still drives no problem so far. The check engine lights stays on not flashing. No triangle lights come up yet and hopefully it won't come up. Do I really need to replace the water pump. I know our temperature gone up lately in California. I just used Torque pro to clear the code. I will start the car again and see what will happen tomorrow. How can I tell if the water pump is completely bad? I checked some youtube vids, its not too hard to take it off and put a new one in. But I just want to make sure I need a new one. Its $230 on Amazon.
    I got 250K miles on it. The coolant level is on max. I usually take good care of my prius. Do most maintenance on my own. I will put my hands to the pump and see if its vibrates tomorrow day time.
    Aisin WPT-190 New OEM Water Pump Kit
    #1 kobear18, Jul 20, 2020
  2. kobear18
    92
    23
    san francisco
    Should I check the coolant temperature. I got the display for that in Torque pro. But I haven't found the display for the engine temperature yet? Where is that? Or should I check engine temp? What is the normal engine temp? and the coolant temp? I will report those numbers tomorrow day time
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    If you are getting the water pump code and at 250k miles, it's probably a safe bet there is something wrong with the water pump;).
    I've replaced (or help replace) 4 of them and each time there is either resistance in the impeller or the casing has swollen, causing the impeller to rub on it:cool:.
    Since the water pump is magnetically driven, you won't be able to diagnose much from the outside:whistle:.
    So I'd look to replace it at the mileage you state(y).
    PriFi, SFO, pjksr02 and 1 other person like this.
  4. kobear18
    92
    23
    san francisco
    just checked coolant temp = 104 F when its on idling. I let the car on for 20min the check engine light didn't come up again. I will try to drive it in short distance and see what happen.
    #4 kobear18, Jul 20, 2020
  5. AzusaPrius
    AzusaPrius Senior Member
    1,875
    821
    You need a waterpump.
    Also get one gallon of toyota coolant.
    Jack it up on the passenger side.
    You can find an aftermarket pump for $125 on ebay.
    Not doing this will have you freaking out and the car shutting down to prevent further damage.
    You will not get a hot temp light.
    10 year old pump with a lot of miles.
    Have fun and be happy like she will.
    PriFi likes this.
  6. kobear18
    92
    23
    san francisco
    yea damn...today its got worse. Engine knocking very bad when started. Torque pro detected cylinder 1 mis-fire. I used to have engine knocking problem once in a while but it wasn't too bad & no check engine light came up back then so I didn't care. Now that the water pump problem and the mis-fire really got my attention. Coolant temperature as follows, at night time, outside temp. 55F and driving in local road 25MPH, the coolant temp. stays around 138F. Day time when outside temp is 67 to 70F, driving on freeway 65 or above, the coolant temp. reached 190F. Do u think thats already overheating?
    In conclusion, the main issue came down to the water pump? Water pump didn't pump coolant to the engine so it caused knocking and mis-fire?
  7. AzusaPrius
    1,875
    821
    It will overheat but has not, the pump is no good but still works somewhat.
    Order it and get it done.
  8. kobear18
    92
    23
    san francisco
    what do u think of the mis-fire? Is it caused by the water pump as well? I'm going to get the
    Bar's Leak HG-1 HEAD SEAL Blown Head Gasket Repair from Amazon. Its got 836 reviews (the most reviews) this kind of product to seal the gasket if its blown and caused the mis-fire. Do you think that its good?
  9. AzusaPrius
    1,875
    821
    If you think you have a HG issue do it with the bad waterpump on.
    The misfire could be as simple as the spark plugs or ignition coils.
    #9 AzusaPrius, Jul 21, 2020
  10. kobear18
    92
    23
    san francisco
    just ordered both the water pump and the head gasket fix. Thursday will be here. Thank you so much for replying to me
    Raytheeagle and AzusaPrius like this.
  11. AzusaPrius
    1,875
    821
    Dont forget you will also need a gallon of toyota accepted coolant once you replace the waterpump.
  12. kobear18
    92
    23
    san francisco
  13. kobear18
    92
    23
    san francisco
    New NGK laser Sparks were replaced at 200k now its only 250k..these were supposed to last 100k. Im thinking maybe coils or the egr cooler need cleaning
  14. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    Well starting to think I've a similar problem, temp up to 94 degrees today on the motorway before dropping back down to 90....normally rock steady 91 degrees never going over that. ( I use hybrid assistant every couple of weeks) think I'm going to get water pump as mileage is 205 thousand and be done with it.
    AzusaPrius, pjksr02 and Raytheeagle like this.
  15. taxidriver50005
    204
    170
    GB
    Excel
    Genuine official Assin water pump ordered, was going to get generic copy but opted for the better one, £243 as against £165 for the copy, amazon did have some cheaper options for ones but not in stock for 6 weeks.
  16. kobear18
    92
    23
    san francisco
    water pump will arrive tomorrow, I will have it installed. I read more posts on here, it could be many problems. Blown head gasket is one of the major ones. I already got the Bar's leak from Amazon. Its got 843 reviews and it should seal it. I did a intake, egr, egr cooler, egr pipe cleaning in Jan. this year. I also changed the pcv valve. I also got new spark plugs 1.5 years ago about 40k miles ago. I ordered new ignition coils set of 4 too. I may do another major cleaning for the intake n the whole egr lines. but new water pump will be in tomorrow. And the bar's leak sealant will be in tomorrow as well. I will keep you guys updated.
  17. AzusaPrius
    1,875
    821
    Please do NOT pour the BAR leak in after you install the new water pump.
    You will clog it and burn that water pump!
    Use the stop leak while the bad water pump is still on and then go for a good drive with the stop leak inside.
  18. ASRDogman
    ASRDogman Senior Member
    6,085
    3,271
    Don't pour any of that crap in your coolant system, before or after the water pump.
    Fix the problem, replace the head gasket...
    ttou68 and Raytheeagle like this.
  19. kobear18
    92
    23
    san francisco
    Hhmm...let me think ... just woke up ... ill replace the water pump first and see what happen...im also skeptics about pouring this bars leak in. I also noticed coolant level gone down a lil bit even not driving. I remember coolant loss about 1 to 2 months ago for no reason but i didnt care much so i just top it off with some coolant mix. There was no engine lights on no nothing so i didnt care
    #19 kobear18, Jul 25, 2020
    Raytheeagle likes this.
  20. kobear18
    92
    23
    san francisco
    Ok photos its really broken...still working on it ..taking a break now.
