P261B On & Off
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Alexander Nunn, Nov 30, 2024.
  1. Alexander Nunn
    Alexander Nunn Junior Member
    Reading
    Hello!
    Starting to get cold here in PA!
    Got this code one morning and it went away by the end of the day. Then a few days later it came back again after start up and went away by end day. Today it came back.
    Wondering if it’s time to replace water pump or if it is a sensor or relay?
    2012 Prius C Three
    120k Miles
    Another good thing to know is a just had the engine coolant and inverter coolant flushed and replaced couple weeks ago.
    let me know if you need to know anything else!
    Thanks !
  2. Leadfoot J. McCoalroller
    8,090
    7,571
    Pennsylvania
    2018 Prius c
    I've been reading about water pumps not hitting advertised RPM late in their lifetimes... I'm inclined to think you're reading an honest error code.
    Alexander Nunn likes this.
  3. Leadfoot J. McCoalroller
    8,090
    7,571
    Pennsylvania
    2018 Prius c
    adding: I've also read about no-name pumps not lasting very long. If I were convinced that I had a real water pump problem in our car I would spend the money for a real Toyota pump.
    ...mind you I'd order it from one of the big dealers that runs a dedicated internet parts sales business, not any of the ones near us. Much better pricing for the genuine article.
    Brian1954 likes this.
  4. Alexander Nunn
    Reading
    I just ordered a new thermostat and AISIN WPT-190. I just got new coolant put in a couple weeks ago. Would you still drain it all or just catch what comes out when I remove both the pump & thermostat?
    Thanks
  5. Leadfoot J. McCoalroller
    8,090
    7,571
    Pennsylvania
    2018 Prius c
    I would catch and re-use, assuming I had a properly clean basin anyway.
  6. Alexander Nunn
    Reading
    So ran into a problem and can’t get the one bolt off. Any suggestions?
  7. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    WD or Blaster overnight.
    If you spun the head ( picture doesn't really show why you can't get it off ) file the head and use a 3/8 " wrench if it's a 10 mm head, and hammer it-(the 3/8" wrench) onto the head if you need to. Or use vice grips or a bolt spliter or heat or all 3 if needed.
    #7 vvillovv, Dec 7, 2024
  8. Leadfoot J. McCoalroller
    8,090
    7,571
    Pennsylvania
    2018 Prius c
    Remember to work it back and forth. Loosen a bit, tighten a bit Loosen a little more tighten a little less.
    That plus penetrating oil, colorful language and vvillovv's suggestions above will get you there.
    And get yourself a new bolt for the reassembly, you should not re-use that one.
  9. Alexander Nunn
    Reading
    Yeah the threads are screwed [lol]
    Will try the penetrating oil and loosen tighten
  10. Mendel Leisk
    41,479
    Spec'd torque for the water pump bolts is 8 ft/lb. Maybe someone's been there before?
    vvillovv likes this.
  11. vvillovv
    4,321
    1,510
    NY
    Is the bolt stuck - not turning at all- or is the bolt spinning in place.
  12. Mendel Leisk
    41,479
    If the latter sometimes levering up on the head while turning helps.
  13. vvillovv
    4,321
    1,510
    NY
    It took a minute or two and an edit or two of mine above before I realized. LOL
  14. Alexander Nunn
    Reading
    So it will turn to tighten but it won’t go any further to loosen. I just sprayed it with penetrating oil and will try again tomorrow.
  15. Alexander Nunn
    Reading
    Is the 2nd Gen the same as the 3rd Gen?
  16. Mendel Leisk
    41,479
    Ah wait a sec. I posted second gen water pump instruction. Prius c is basically a gen 2 engine, I made the leap of logic that consequently the water pump would be the same. It may be. Take it with a grain of salt though.
    That's all I've got; don't have a Prius c shop manual. A pdf version likely doesn't exist. :(
  17. Alexander Nunn
    Reading
    found one !
    vvillovv and Mendel Leisk like this.
  18. Mendel Leisk
    41,479
    And the torque specs are different. :oops:
  19. Alexander Nunn
    Reading
    The bolt is off everyone !!!
    vvillovv, Mendel Leisk and Brian1954 like this.
