p261b, stop and go, power cycle rapid temp drop, triangle, coolant pump
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ben Schneider, Feb 24, 2019.
  1. Ben Schneider
    Ben Schneider Junior Member
    central florida
    started getting triangle code + p261b... changed trans oil and coolants...
    mostly went away
    car mostly around 190f regularly
    codes happen when a/c on for a while and/or especially in stop and go traffic.
    drove yesterday in 90 degree weather for 3 hours mostly non stop - code came up in stop and go traffic (where it seems to usually come up), engine temp climbing to 220f
    i pulled over, turned car off, then turned it on 2 seconds later. engine temp rapidly went down to 186f, in about 30 seconds.
    ready to change coolant pump if necessary, but strange that overheating does not happen all the time and strange that turning the car off and on right away causes a 30 degree temp drop back to normal
  2. Ben Schneider
    central florida
    also it seems like as there is some heat in the engine there are momentary reductions in hp
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Thermostat?
    Ben Schneider likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    How many miles on your Prius?
  5. Ben Schneider
    central florida
    that is a good guess, though, how would the temperature go down fast after a power cycle
  6. Ben Schneider
    central florida
    190k
    Raytheeagle likes this.
  7. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Make sure all connections are tight, but there have been accounts of the water pump failing;).
    I would replace both the thermostat and pump just to make sure you get either cause:).
    Good luck and keep us posted (y).
    Ben Schneider, m.wynn and tankyuong like this.
  8. Ben Schneider
    central florida
    i will check the connections... there don't seem to be any leaks
    tempting to replace those, but i don't yet want to do guessing game that becomes a money pit
    appreciated.
  9. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    If you do the same and continue to drive it, you’ll be repairing many more components ;).
    Ensure you have a good code reader to catch all the codes and then prioritize the work. Good luck and keep us posted (y).
    Ben Schneider and m.wynn like this.
  10. tweedle99
    tweedle99 Member
    124
    69
    Round Rock, TX
    I had the same code and was able to get home after restarting the car. Replaced the pump and the code went away permanently. The pump impeller appear to be turning fine but has a little more resistance. It probably throw codes when it stop spinning. I would replace the pump before other components fail, like Ray said above.
    Pretty easy to change out, just take out the air snorkel. I didn't change out the thermostat but hindsight, should have.
    Ben Schneider, m.wynn and Raytheeagle like this.
  11. Ben Schneider
    central florida
    i truly appreciate your advice...
    went to tampa hybrids (they basically only sell priuses) yesterday. they were pretty sure it is the pump. though the assistant started checking the inverter stuff and squeezing the hoses when i asked him to check the wiring.
    going to replace the pump and probably the thermostat ... i am seeing the temp on some thermostats as 180 - is that the right temp ?
  12. tankyuong
    1,555
    662
    Central MO
    Average is in the 190s
  13. tweedle99
    tweedle99 Member
    124
    69
    Round Rock, TX
    Might as well do coolant flush while you are at it since you are already draining the coolant, if you haven't done so.
  14. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Clean the egr circuit since you’ll have the coolant out and the mileage is up there;).
  15. Ben Schneider
    central florida
    was attempting to change pump a few minutes ago...
    got 2 bolts off
    there was a 1/2" aluminum pipe with a diamond washer at the bottom ( in the way of one bolt so i began to disconnect it (10mm) and it seems to have depressurized or something... anyone know what that is... i hope not bad
  16. tweedle99
    tweedle99 Member
    124
    69
    Round Rock, TX
    you can try taking off the fender liner to get to the bolts. No need to jack up the car, just turn the wheel out.
  17. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Pretty sure that’s the ac system:cool:.
    tankyuong and Ben Schneider like this.
  18. Ben Schneider
    central florida
    location in pink (this is not my photo, borrowed from net) - i tried to move a thin aluminum pipe to better get at the bolts... then a rapid depressurization of something - did i depressurize ac ?
  19. Ben Schneider
    central florida
    did it, ty
