P3000 and block-failure, but cells test to good voltages?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by CaptainSparkle, May 6, 2022.
  1. CaptainSparkle
    CaptainSparkle New Member
    New Mexico
    Hello,
    I'm new to the forum, but I've been a lurker for a while and have used the resources for many a fault fix!
    I have a 2005 Prius, about 320K miles (some toyota '05s odometers only display up to 299999)
    I recently had all the warning lights, OBD checked and got the P0A80, P3000 and P3014 (block 4) codes-- confirmed block 4 would drop very low with the live data. Not my first time, so I took the traction battery out low and behold, one of the block 4 cells was reading very low voltage (6.6v). All other cells were at 7.9v-8.0v. So I swapped out the bad cell, (and its pair because I borked the torque reinstalling it. whoops!). Get it all back in, no codes and it runs great for about 30 minutes. then it starts firing P3000 and P3021 (block 11) codes (it does NOT display P0a80). I can clear them, and it runs fine for a few minutes before coming back.
    My OBD reader shows block 11 a little lower than others, but still in a good range. it does sometimes drop to a low voltage for a point before going back to normal. It is more erratic than other blocks. I replaced the bus-bars with the nickel-plated ones and new screws the last time I replaced cells.
    Before I take it back out for frustration, is it possible that two cells testing at a good voltage (7.9-8.0v) suddenly drop off to cause a fault code? is it more likely that I messed up something re-installing? (Not my first time doing this, so I'm pretty cautious but can still be scattered). Is it possible to cells have faults that won't check out with a voltage meter?
    Could it be something else causing the fault?
    I had a refurbished replacement originally, and it was garbage. they did two warranty replacements in a year, and since then I've just been replacing cells when they go. Lil Sparky is great, but I know I'll be needing to move on sooner rather than later, so the cheaper replacements is the way to go for me right now.
    Thanks! I wasn't able to get Dr. Prius working with my OBD II reader, but I'll look into a better reader if that can help this and future diagnosis.
  2. PriusCamper
    PriusCamper Senior Member
    11,089
    4,513
    Pacific Northwest, USA
    Here's buyer's guide for OBD2 that works with Dr. Prius app: Hybrid battery diagnostic and repair tool for Toyota and Lexus
    I just bought one of these for $15 and it works well: Panlong Bluetooth OBD2 OBDII Car Diagnostic Scanner Code Reader Check Engine ... | eBay
    With Dr. Prius there's a display for "voltage difference" between the blocks and as amps go in and amps come out the voltage difference will change. A healthy pack rarely goes higher than 0.2v and and unhealthy pack will be up in the 0.3v - 0.5v with wild swings to over a volt, which is when P3000 shows up.
    You can reorganize the modules to balance things out sometimes and after a module replacement you get the best results charging & balancing the pack with a high voltage trickle charger like Maxx volts or Hybrid Automotive. Or, you can build your own for about $100: Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
    In terms of module testing, the next step is to do a load test on each one. Which basically means measuring the voltage drop of the module for 2 minutes when connected to a 12v 50W bulb, such as your halogen headlight bulb if that's the type of headlights you have. A healthy module will lose about 0.3v during that light bulb and an unhealthy module will have a loss of voltage up above 0.42 or higher.
    There's way more to it than that, so when you're ready for more, let us know?
  3. vvillovv
    vvillovv Senior Member
    3,655
    1,286
    NY
    What you're experiencing after replacing Block 4 and putting the pack back in the car, than seeing Block 11 throw codes is know in the vernacular as the Wack a Mole syndrome. It's impossible to get cell / module / block / pack health estimates from voltage readings alone, as @PriusCamper mentioned above.
    What you are seeing when you take a voltage reading is called Resting Voltage. Resting Voltage will not tell you by itself if a cell or a (6 cell module) will sustain that voltage when it's under a load (like when it's running the motor in the car).
    So from what you wrote in your post above Block 11 is also weak, just not as weak as Block 4 was before you replaced those 2 modules in Block 4. Since Block 4 threw the P0A80 code and Block 11 did not throw the P0A80 dtc (diagnostic trouble code). At least not yet, anyways .... fingers crossed ...
  4. Tombukt2
    Tombukt2 Senior Member
    9,068
    1,571
    Durham NC
    So you keep on keeping on and in short order have labour n costs of the 1400 new HV . And it go 18 yrs more . But your mind will not justify fix because you desire newer vehicle . My ole Gen2 at 350K just put New battery in ready to take to 666K. I've no desires or wants to manage in these processes crept to move my Azz in AC and heat wen needed.
  5. CaptainSparkle
    New Mexico
    after much shipping delay, I was able to get an OBDII scanner that worked with Dr. Prius.
    First up: I did start to finally see the P0A80 code. Additionally, unlike my other failures, the car would go into Limp mode after a few minutes of the code. It is still variable. sometimes I've driven it for 20-30 minutes without codes, sometimes they are immediate.
    With Dr. Prius, the full battery test showed some issues with block 11 under upper voltage load -- I could never get the the bottom voltage to trigger (turns out I'm a giant baby when it comes to slamming on the brakes). Sometimes it would complain about blocks 1 and 2 in "internal resistance", but that would also come and go.
    Watching the graph, voltage differences were pretty stark, often over 1v when under load. The voltages also seemed to jump around a lot.
    Block 11 was the worst by far, but the others weren't looking great by the eye and the size of the bars.
    And finally, the "life expectancy" test, I had some troubles figuring out what to do, but it gave my battery pack a whopping 1.6% of life remaining.
    So I love having data, and though I've had some troubles recording and exporting, I'm glad Dr. prius shows these data as graphs. As expected, a lot of my battery blocks are in poor condition, and block 11 seems to have the most issues.
    I guess my main question is: are the bad readings possible the cause of something beyond the battery cells, or even the battery pack?
    e.g. could the battery ECU cause bad readings of voltages, and/or could something like the generator be failing and causing similar issues?
    I'd like to get Sparky pack up and going, even if it means a new set of cells, or possible a whole repaired battery pack, but I don't want to spend the time and money doing that only to find out the problem is somewhere else.
    Thanks!
  6. dolj
    dolj Senior Member
    7,643
    3,858
    Wellington, New Zealand
    It is looking like your hybrid vehicle (HV) battery is definitely the issue.
    Since you would consider a new pack, just do that and be done with it.
    Avoid remanufactured rebuilt or whatever else they call a secondhand pack, they are all a collection of old cells waiting to die.
    Shop around the dealers to get your best price.
    newpriusbatteries.com also has an aftermarket option of new modules to replace all your old ones, but it involves someone removing the old modules and installing the new modules. They look different too when compared to the OEM modules, but you get to sell your old modules to offset some of the cost. If you are not up to doing the job yourself you can always contract someone to do it for you.
    There is also a lithium-based option for a new battery that, so far, has not reported any issues. However, this option is currently (or soon will be) out of stock for up to six months or more as they have supply issues.
    #6 dolj, May 20, 2022
  7. mech1222
    mech1222 Junior Member
    32
    usa
    i would load test the cells individually on block 11 or whole pack and reaplce one or both on block 11...pretty sure you have alot more life left on that pack...
    also, if you have accss to a midtronics md8000 or similiar from midtronics, it can test the cells, and verify a bad one usually...
  8. CaptainSparkle
    New Mexico
    SoooOOooooo.... FUNNY STORY.
    Always check the calibration on your torque wrenches friends! And... maybe always check that you actually torqued everything properly.
    I started to take the battery out and see if there was any corrosion or anything, and low and behold on block 11 one of the bus-bar bolts was surprisingly easy to unscrew... I got my torque wrench re-calibrated, then re tightened, re assembled everything and no more throwing codes! I think I got a little gun-shy after the threaded part of a battery cell got over-torqued without my wrench clicking. maybe i was too cautious.
    I went back through Dr. Prius testing, it flags block 2 as a potential future problem, but otherwise everything is back to less than 0.3 volt differential. it passed load tests positive and negative, and 'battery life' is now at about 60%. So Sparky is back to drive-able. I'm sure I'll get more P030XX codes before too long, given I've replaced 11 cells (from a crap refurb) without doing any intentional re-balancing-- but given other issues unrelated to the battery (a sealed-but-problematic windshield crack, likely AC leak, no cruise control, and needing schedule maintenance twice the value of the car, etc), eeking out a few more months is a win all around!
    Only other problem is that the battery temperatures get high; about 120F. I do live in a high-desert that also has plentiful car-crime. Daytime temps are well into the high 90s; I can leave the windows open at work, but weekend outings are gonna be warm. Learning how to keep the battery fan on high is the next step. Thanks again everyone! This is a great resource and a great group of people to help with problem solving <3
