P3000, POA82 and B1421
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by flyboy09, Jul 13, 2016.
  1. flyboy09
    flyboy09 Junior Member
    Seymour Tennessee
    P3000. Snowflake shows detail code 2 (123), POA82. Snowflake shows heading of Hybrid battery pack cooling fan1 performance/stuck off. much more data available but unable to determine what data is relevant...tb1=123.1F, tb2=131.7, tb3=122.0...believe all 14 battery blocks are good with high 16.45 to lowest 16.31. pretty sure B1421. Is passenger side sunlight monitor error as health check performed at night.
    cleared all codes... drove to work and back 54 miles...no new codes
    could the problem be a stuck relay switch?
  2. strawbrad
    953
    1,001
    I'm not sure if your code is a match to this. More than one PC member have reported corroded connections at the plug for the battery fan. You'll need to remove the passenger side trim panel to get to the fan.
    Brad
