P3019 question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TheGMann, Aug 14, 2019.
  1. TheGMann
    TheGMann Junior Member
    wisconsin
    P3019 question
    The code indicates a module #9 bank fault,
    Just curious does each bank have its own fault code?
    Thanks
  2. JC91006
    16,477
    8,393
    This indicates block 9, which consists of 2 individual modules. 1 of those modules most likely failed.
    Yes each block has it's own failure code
    Skibob and Raytheeagle like this.
  3. TheGMann
    wisconsin
    thanks for the info and correcting me from bank to block, my mind works right but the fingers don't follow but I do like getting the trminology correct
    Raytheeagle likes this.
  4. TheGMann
    wisconsin
    Follow up question: Load tested Block 9 pair (18 and 19 from terminal end) and they both appear good. (quick drop from full voltage, then plateaus with a slow voltage drop, then when getting below 6v very fast drop). Similar to a good cell.
    Next step is to load test all, will update.
    Is the 3019 code specific to block 9 modules or is it for a range of modules? Any ideas are appreciated.
