P3030 on Prius 2006
Discussion in 'Gen 2 Prius Main Forum' started by kolez2000, Nov 12, 2021.
  1. kolez2000
    kolez2000 Junior Member
    64
    West Africa
    Hello, I scanned a Prius 2006 and got the code p3030. I checked the battery wire harness and there wires were ok. How to hear from the prof here. Thanks
    49,542
    SFO likes this.
  3. kolez2000
    64
    West Africa
    @bisco thanks.....
    I am also have the cat heating up sometimes.
    Whenever I drive the car and parks it, th coolant overfill the reservoir at times...it heats up at times and I would have to park for few mins to top up coolant. What do you think could be the issues? I scanned but there was not fault code.
  4. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    You top up coolant with 50/50 coolant mix, not just water, correct?
  5. bisco
    49,542
    stuck thermostat?
  6. kolez2000
    64
    West Africa
    You suggest I check the thermostat right? I would do that. Thanks
  7. kolez2000
    64
    West Africa
    Thanks, I would remove the thermostat and treat it to be sure...I would update you
