P3030
Discussion in 'Gen 2 Prius Main Forum' started by Sharnold, Mar 14, 2019.
  1. Sharnold
    Sharnold Active Member
    379
    119
    Alabama
    2005 prius had the usual battery issues triangle of death no start had multiple codes now after I replaced 3 cells in the battery I'm still getting this code
  2. JimboPalmer
    12,470
    6,868
    Greenwood MS USA
  3. Sharnold
    379
    119
    Alabama
  4. JimboPalmer
    12,470
    6,868
    Greenwood MS USA
    As i read this, it can be the sense wires that are broken/corroded, not just the bus bars.
    "At this point you know there is a broken or corroded circuit in the harness, creating an open. The sensing circuits are very small 22 gauge wires connected to thin flat tabs that mount at the bus bars, which are easily fractured." - LG
    Not everyone responds back with what solved their problem, but I have never seen an ECU be the problem, although many have been replaced.
  5. Sharnold
    379
    119
    Alabama
    I replaced all the sense wires also when I replaced the bus bars
  6. Sharnold
    379
    119
    Alabama
    I still have 4 other batteries I'll replace the ecu next and try it out then work from there
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,266
    5,964
    Columbia, SC
    Do you have techstream or any phone app that lets you look at block voltages? This problem should easily show up and point you in the direction of which block(s) are reading an unusual voltage.
    If not, you really need to get it. It makes life a lot easier when working with the HV batteries.
  8. Sharnold
    379
    119
    Alabama
    All the blocks have the correct voltage I have tech stream and a tablet
  9. TMR-JWAP
    6,266
    5,964
    Columbia, SC
    What does the freeze frame data show for the P3030? It's showing all voltages as normal?
  10. TMR-JWAP
    6,266
    5,964
    Columbia, SC
    This is another good reason to buy a brand new sensor harness from Toyota. The man hours and effort involved in re-using an old harness is crazy compared to just purchasing a new one.
  11. Sharnold
    379
    119
    Alabama
  12. Sharnold
    379
    119
    Alabama
    After the battery sits a day without cranking all cells are 7.5
  13. TMR-JWAP
    6,266
    5,964
    Columbia, SC
    Those voltages are normal for when you measure modules individually with a meter. But that's not the problem. They are not normal voltages when being monitored by the ecu.
    Techstream should have freeze frame data for a p3030 that shows all 14 block voltages (as measured via the sensor harness) at the time of the fault. If your modules are all exactly 7.95v then each block would in theory show 15.90v on techstream. The freezeframe data for the p3030 should show one or more blocks with a whacked number (assuming the snapshot caught the transient).
    Something is happening between where a tab is attached to the terminal and the ecu. Either a voltage is off due to wiring issues or as you mentioned, the ecu is acting weird. The vast majority of the time, it is due to corrosion affecting the sensor tabs, micro cracks in the crimp area, or the plug not making good contact at the ecu.
    SFO likes this.
  14. Sharnold
    379
    119
    Alabama
    I'll use tech stream when I get to the shop again later if I have to I'll change the ECU and I'll keep you posted
  15. Sharnold
    379
    119
    Alabama
    After replacing the ecu and changing the bus bars and sensor wires for a 3rd time var is still showing the same code with a no start condition and as soon as I clear the code it comes back smh on this one
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Are you sure you have the orange safety plug locked? Push the plug in flip up the lever and then push that lever straight down till it clicks.
    Did you balance the whole pack with a product like Prolong? That's really important and extremely beneficial. Takes at least 30 hours. Battery really likes that.
    Did you load test each module? That's imperative one module going flat faster then normal then the rest is identified by the ecu and it will throw a alarm.
    lastly look at the white plug that goes to the ecu look at it carefully make sure there is no corrosion on the plug or receptacle. Corrosion on the sense wires are sneaky it runs all the way up the wire under the wire coating so you never know how rotten it is.
  17. Sharnold
    379
    119
    Alabama
    Unfortunately it's not the battery cells and yes I load test them individually but I'm gonna just order new bus bars and sensor wires I've tried four different plugs three sets of harnesses and 3 ECUs this isn't my first battery nor my last but when the owner wants to be cheap he ends up just paying me more in labor
  18. Sharnold
    379
    119
    Alabama
    I gave up on it for the day while I worked on a ford 6.0 also but I also didnt bolt the casing for the battery to the floor pans ground issue maybe?
  19. TMR-JWAP
    6,266
    5,964
    Columbia, SC
    Yes...............I believe we've had reports of this previously. At least one bolt needs to be installed and torqued.
    Raytheeagle and Sharnold like this.
  20. Sharnold
    379
    119
    Alabama
    Thank you it didn't hit me till I started driving home
