P3190 code troubleshooting
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by OC63RAG, Aug 14, 2021.
  1. OC63RAG
    OC63RAG Member
    94
    42
    Are there any apps that give a definitive cause to this error code? It sounds like it covers multiple potential causes but you still need to check the components one by one.
    In this example, ‘08 with half a tank of gas, 190K miles, one year old refurb HV battery, driving along and the engine cuts out and the check engine light came on. Starts back up and seems ok, drove to Autozone to get it scanned and the P3190 shows up.
    I’ve searched and it I can’t find a solution. Thanks for any help.
  2. JC91006
    16,674
    8,519
    The engine normally cuts out on the Prius, so how is this a problem? The check engine light is usually emissions related
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    How's the fuel pump doing:whistle:?
    I'd start there(y).
    OC63RAG and JC91006 like this.
  4. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    No.
    That's because any one of those things could be the problem.
