Painting replacement parts DIY
Discussion in 'Gen 2 Prius Main Forum' started by Omar Haddad, Feb 28, 2025.
  1. Omar Haddad
    Omar Haddad Junior Member
    25
    Sag Harbor, NY
    Hi everyone,
    It is my first time painting body parts. I have a replacement fender and front bumper, both used. They have a few scratches and other minor things, but the paint on the parts looks nice and shiny. It's just the wrong color. I came up with a spray painting plan from watching several tutorials, but I want to double check it with more experienced prius owners and maybe hear any tips anyone may have. I obviously don't expect this paint job to look extremely professional. Just decent.
    I would first sand the part thoroughly with 800 grit sand paper, apply one layer of urethane primer of the right color, wait about fifteen minutes for it to dry, and sand the part again if it is not very smooth. Then I would clean the surface with wax remover and/or alcohol, and then apply the paint. I would apply three layers, giving them about ten minutes in between so each layer is still slightly humid before applying the next, and finally I would apply three layers of clear coat.
    While painting I'll use a respirator, do it outdoors on a sunny day, be careful, etc., etc. Does this plan sound like it could work? Is there anything that I would be overdoing or that I'm missing? I am wondering also if the cleaning step right before applying the paint has to be done with both wax remover and alcohol or if only alcohol would be fine.
    I appreciate all input. Thank you!
    Thanks very much.
  2. pasadena_commut
    pasadena_commut Senior Member
    2,199
    657
    Southern California
    Not my area of expertise at all, but...
    I believe that it is necessary to add something to the paint that goes on the bumper to make it more flexible.
    Expect bugs to not only get stuck in the paint, but some may actually be attracted to it. I painted our mailbox once and a cloud of little flies appeared out of nowhere and committed mass suicide on it.
    If you are going to use 2K clear coat be aware that you need a chemical grade respirator and, ideally, a bunny suit with gloves. Look at the pictures here, for instance:
    Specialized PPE Protects Automotive Paint Shop Workers | Liberty Safety
    Adjust your expectations. If you go into this expecting it to turn out like a professional paint job you are likely to be disappointed. If you want it to look "good enough" from 20 ft. away you can probably achieve that.
    Figure out the costs for all of the materials and equipment you would need. Ask several paint shops what they would charge to do the fender and bumper (when you have already done the prep work, like sanding it, or stripping it to the metal.) If the two numbers are close have the pros do it.
    Before painting do a test assembly. Verify that it all goes together the way you want.
    MAX2 likes this.
  3. Omar Haddad
    25
    Sag Harbor, NY
    Thank you!
  4. highmilesgarage
    highmilesgarage Active Member
    425
    151
    Kansas City
    are you going to use spray cans? because it will not be a perfect match. I'll start with 600 followed by 800 when sanding the parts. Primer sprayed only on parts that has no paint on it. Wax and grease remover can do the job in cleaning, no need for alcohol. Don't paint on direct sunlight since paint will dry up quickly and you'll get tiger stripes (not that good looking) Paint indoors to avoid bugs, dust and anything carried by the wind (if possible avoid windy day) Poly-urethane clear coat use needs a proper respirator which you could buy cheap in Harbor Freight (protect your lungs)
    I've switched to using a proper HVLP spray and used Oreilly to match the paint (not 100% match due to age) Spray cans work if you look at it at a distance.
    Omar Haddad likes this.
  5. Omar Haddad
    25
    Sag Harbor, NY
    Thank you very much!
  6. Omar Haddad
    25
    Sag Harbor, NY
    For wax remover, what about Simple Green? I have that already...
  7. Omar Haddad
    25
    Sag Harbor, NY
    I believe you mean adhesive promoter, to make the paint stick, because it's plastic. Is that right?
  8. pasadena_commut
    2,199
    657
    Southern California
    I believe that it is called a flex additive.
    ColoradoCrow and Omar Haddad like this.
  9. Frontporch
    Frontporch Active Member
    494
    107
    Nj
    I would buy decent paint equipment if you don't already have it. Since you mentioned urethane paints I assume you are not going down the slippery slope that i went down about a year ago. I watched several you tube videos of people painting parts with duplicolor perfect match and 2k Clear. What I thought was the downside of painting was the clear without hardener.. it couldn't endure day to day driving. Most touch up paints sell laquer paints. That's OK to spray over a factory finish.
    What I learned is that duplicolor is LAQUER and my 2k clear was not compatible... like oil and water. I should have known better, but I was convinced by all the youtube hype. The clear is and will continue to slowly peel from the color coat ( which wasn't a perfect match just the same)
    I later talked to the manufacturer of the 2k clear and he directed me to a paint supplier. I had a nice conversation with that guy and found out that instead of buying about $100 of duplicolor paint I could have gotten about the right amount of enamel primer and color. I could have used the cans of 2k clear on that and it would have come out much better.
    Maybe see if you can find a similar paint supplier and get the info from them. This guy was really nice and took some time, which I was surprised about.
    Lots of other good advice on the respones here and make sure you have protective gear... I also called 3M to get some peace of mind in my selection of respirator gear. Even though the stuff was nasty, according to them it didn't require any special positive pressure system, just the right cartridges.
  10. Frontporch
    494
    107
    Nj
    i picked up some was remover from amazon. it was some serious stuff... got the original sanded surface nice and clean. I am not sure I would use wax remover between paint coats, maybe just a tac rag if there is lots of paint dust. Thinking back to the videos I watched there were definitely some good ones. I would trust the guy in the spray booth over the guy in his back yard.
  11. ColoradoCrow
    ColoradoCrow Senior Member
    1,090
    447
    Leawood, KS
    I
    For sure....use a flex additive for the bumper. Other wise you are wasting time and money... Also I would paint inside a 2 car garage. I wet the floor down before painting and created a poor mans spray booth with tarps on all 4 sides and hung a light high above to I could see really well. I did use spray cans but the kit I got was from a place in Chicago. 2 cans of top coat for a bumper, 3 cans for the hood a fender would be a 1 can per fender. From Amazon the Vendor is Spectral Paints. Primer,base coat and top coat 3 pack. $62.99 worth every penny. Turn the can upside down and spray between coats to clear the tip. Remove the hood and hang it from a rope like a slab of meat. It came out really, really, nice. So much so I then hated the OEM roof paint....and wanted to redo that as well..LOL
  12. Frontporch
    494
    107
    Nj
    Is the paint from Spectral a laquer? I have bought kits from other sellers and that’s what it seems to be. I would be wary of using anything without hardener on a part of the car that can be hit and other road debris. Makes sense for a hood but now that I say it I am wondering if 2k clear is good for flexible parts like bumpers. Definitely can’t use 2k clear on laquer. May not be advisable on a bumper that can flex. On the Prius it seems that hoods take the brunt of the damage from rocks and the bumpers do ok. A fender and bumper might not need the hardener as much. Not sure
  13. Mendel Leisk
    40,426
    For DIY, what’s the best alternative to lacquer, enamel?
  14. Frontporch
    494
    107
    Nj
    I'm not qualified to answer but I always believed laquer is more forgiving for a novice and allows for buffing more so than enamel. I would think enamel or some kind of urethane is what would be closer to a factory finish. A DIY painter wouldn't have access to a fancy paint booth or special drying equipment, but I think you can go a long way with paint + hardener. The very limited pot life of that mix is why it isn't sold in a can. The exception is the specialized cans that have paint and hardener separated until you break a seal and mix them together. The 2K clear that I used had that. Its expensive but works well.
    If I try to paint another panel I will probably just buy enamel paint + hardener, maybe urethane... I have old equipment and have never tried the HVLP setup that seems common today. Would be interested to hear more from people who are able to pull this off... Another issue is it definitely is a learned skill, but I am not sure how many people would take the time to practice. I didn't and the work shows it.
