pair phone with broken touch screen x
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Royhall, May 27, 2018.
  1. Royhall
    Royhall New Member
    Ga
    If there another way to pair a phone When your touchscreen doesn’t work
  2. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    ? Sorry pls clarify.
  3. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    On the phone or the car? If the phone's touch screen doesn't work, I don't know how you'd use the phone at all.
    EyePrime likes this.
  4. Royhall
    Royhall New Member
    Ga
    The touch screen will not respond to touch. I would like to pair a phone but can’t get to phone settings to pair
  5. jerrymildred
    11,511
    14,113
    Tampa, FL
    Which touch screen? The phone or the car??
  6. Royhall
    Royhall New Member
    Ga
    The touch screen on my Prius is in responsive to touch (mfd). Therefore I can access the pair settings on my mfd.
  7. jerrymildred
    11,511
    14,113
    Tampa, FL
    Then I think you're stuck till you get that MFD replaced. Not hard to do. There's a good video on YouTube showing how to replace the combination meter (CM). You just need to follow it part way through.
    You can find replacement MFDs on EBay for a couple hundred dollars.
