Panel mounted USB port for seat heater switch breakout?
Discussion in 'Gen 3 Prius Audio and Electronics' started by anon_prius, Aug 14, 2019.
  1. anon_prius
    anon_prius Junior Member
    32
    Has anyone found a panel mounted usb extender that will fit into the breakout panel next to the 12V outlet (used for seat heater switches)? I am upgrading the factory radio to a Android Auto capable head unit with a rear USB port and would like to extend it to this location. I have found some panel-mounted USB ports in slightly smaller dimensions but nothing that wouldn't require dremel work.
  2. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    Going to be very difficult finding an exact match for that panel. What I did was order this from Amazon:
    BATIGE USB 3.0 & 3.5mm Car Mount Flush Cable 3.5mm + USB3.0 AUX Extension Dash Panel Waterproof Mount Cable For Car Boat and Motorcycle - 3ft
    It has a USB 3.0 port AND a 3.5mm stereo phono port (for AUX) and requires a carefully deployed and sharp 1 1/8" paddle bit/cordless drill to create the opening for the item. Makes for a nice addition. I'd add a pic, but it's still dark here in the High Desert.
    #2 Ed Beaty, Aug 15, 2019
  3. Ed Beaty
    334
    311
    Salt Lake City
    Here's a pic of the installation (with center panel removed):
    Dael, anon_prius, mrand and 1 other person like this.
  4. mrand
    mrand Junior Member
    DFW
    2014 Prius v wagon
    Not answering your question - but wondering what head units you considered?
  5. anon_prius
    32
    That looks good, and exactly what I would do if I had seat heaters, but my brain just couldn't handle drilling into the dash next to a blank breakout.
    I am installing a Pioneer DMH-1500NEX. At the end of the day I went for the biggest screen, w/ Android Auto, at the lowest price point. If I had more money to blow I would have future-proofed with wireless Android Auto, but at this point only a handful of phones support it.
  6. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Do you still need the 12V outlet? I bought a 2-plug USB adapter that replaced the 12V outlet.
  7. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    #7 bobzchemist, Aug 22, 2019
  8. anon_prius
    32
  9. anon_prius
    32
    Fit perfectly! I installed it in the breakout just below the ignition button.
    ASRDogman likes this.
  10. ASRDogman
    ASRDogman Senior Member
    7,792
    3,976
    That is the same one I have. I also installed it under the start button.
    I am able to us a short usb and audio cable. Works perfectly.
  11. Maarten28
    415
    224
    Netherlands
    Also a nice location. It's the spot for the button for the optional automatic parking (which I have never gotten to work properly).
  12. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
