Panel under car came loose...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hightowersmith, Nov 21, 2014.
  1. hightowersmith
    hightowersmith New Member
    Dallas, Texas
    I heard a strange sound driving about an hour ago, like I was dragging a plastic gallon jug. Looked under the car and saw a section of the under side had come loose and was against the pavement. Still attached though.
    I'm scheduled to drive from Dallas to New Orleans first thing tomorrow. For a wedding.
    I have a small window of time in the early morning, and can make a very hurried run to a dealership when they open at 7. That's if this is realistic to quickly fix.
    Otherwise I can rent a car and leave this for next week.
    Please - any suggestions?
  2. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    I believe it's only purpose is to smooth out the air flow on the underside for better MPG.
    The dealer should be able to do a quick fix for you.
    Have a good trip.
    Dan
  3. Mendel Leisk
    38,711
    The dealership could be part of the problem, too. If it's similar to the hatchback, the (rushed) mechanics are likely just opening the local flap, which can stress the hinge, and/or rushing removal/install of the cover, losing/breaking fasteners. To be fair, it could also be due to driving over a few curbs or sim.
  4. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Unfortunately, as Mendel mentioned, the dealers don't follow the prescribed repair manual instructions, which says to remove the entire engine under cover when changing the oil. They typically just open the flap beneath the oil filter, which has a weak plastic hinge. Mine fell off on the highway and I replaced the entire panel. I do my own oil changes now, and remove the entire cover, which gives me the opportunity to look around underneath for any other potential problems. Good luck.
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,967
    4,710
    Texas Hill Country
    I have had mechanics break the fasteners. It would be best to rig it up at the house before going to the dealership rather than further damaging the cover.
  6. bisco
    49,455
    climb under with some bailing wire and snips. you can do a quick fix for your trip and something more complete when time is available.
  7. Mike500
    Mike500 Senior Member
    2,593
    764
    Every time that I inspected the undercover, after a FREE oil change performed by my dealer, at least one or two of those plastic "push in" rivet clips were loose or improperly fastened. That was with the first three oil changes.
    If you have eve removed the entire under engine panel, you'd find that the "leading front edge" is held on with a number of M6 bolts threaded into captive welded in nuts for this high stress point. By using plastic rivets, Toyota engineers failed to realize the stress that the "trailing edge" back at the oil change door gets.
    After the third oil change, I took action and installed two M6 "RivNuts" into the two larger holes that took the gray headed plastic rivets. No drilling on the metal underneath was needed, since the holes were the correct diameter.
    I have the special installing tool, but for two "RivNuts," a simple tool can be easily made.
    Make Your Own RivNut Tool | Carolina Rover Owners Club
    One "RivNut" is all that's needed on the panel and one on the oil change door.
    For the fourth FREE oil change, the dealer, again failed to replace the plastic rivets correctly, but the bolts held fast.
    hightowersmith and mracko like this.
