Panels near Steering Wheel
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Tlyke1983, Oct 19, 2006.
  1. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    There are 2 panels to the right of the display dimmer switch. Any suggestions as to what I could have installed there?
  2. orionll
    orionll Active Member
    1,115
    <div class='quotetop'>QUOTE(Tlyke1983 @ Oct 19 2006, 03:53 PM) [snapback]335292[/snapback]</div>
    I think the panels are for IPA(an option in European Prii and Japanese Prii that will make the car park it's self) and the Japanese and European EV Buttton. You can put just about anything that fits in there in there. There is an EV mod that uses the slot you are talking about and don't think about IPA. Sure you can spend alot of money and time installing the parts for IPA, but it would not be worth it(well at least to me). But it would be really cool if you did do that.
  3. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    Hmm... well thanks for letting me know but I'm really not interested in screwing up the car which I am bound to do if I start fiddling around.
    Thanks Again
    Tamara
  4. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Yeah, it's for the EV button and something else. The image below is from the '04/'05 Prius so there is only one slot. This image shows an installed EV Button.
  5. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    What exactly does EV mean?
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Oct 19 2006, 10:04 PM) [snapback]335363[/snapback]</div>
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(Tlyke1983 @ Oct 19 2006, 09:23 PM) [snapback]335366[/snapback]</div>
    Electric Vehicle
  7. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(Tlyke1983 @ Oct 19 2006, 10:23 PM) [snapback]335366[/snapback]</div>
    Electric Vehicle mode. There are aftermarket kits and DIY instructions. Basically, keeps the gas engine off if possible (withing a given speed limit and battery charge limits etc.)
  8. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    that pic must be from an 04... the 05 dimmer looks different.
  9. InfideNino
    InfideNino New Member
    44
    My avatar shows all three slots filled. From left to right: aiming the headlights, EV, IPA.
  10. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    <div class='quotetop'>QUOTE(galaxee @ Oct 19 2006, 10:38 PM) [snapback]335374[/snapback]</div>
    Yeah. I don't think it's the dimmer; I think it's the adjustment for the auto-leveling headlights. I vaguely recall reading somewhere that you can adjust the level of the headlights in the European (Japanese?) Prius.
  11. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    I stuck in a push button for the "anytime reverse camera" mod, and a switch for the "speed sensor defeat" (both the bluetooth and the nav).
  12. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    So you have your car set up so you can just push a button and the back up camera will turn on whenever?
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 20 2006, 08:55 AM) [snapback]335481[/snapback]</div>
  13. eagle33199
    5,122
    268
    2015 Prius v wagon
    Yup. Anytime, regardless of which gear i'm in :D
    Wish i could take credit for it, but others got to the mod first, and i am a lowly copier.
  14. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    That is frickin SWEET!!!!! How hard was it? How much do you charge for this service?
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 20 2006, 11:35 AM) [snapback]335566[/snapback]</div>
  15. eagle33199
    5,122
    268
    2015 Prius v wagon
    It's not terribly difficult, if you know what you're doing. Darell provides a pretty good explanation of whats involved in his mods section: http://evnut.com/prius_mfd_video.htm
    If you don't know how to solder, i wouldn't make this your first try, though! The cost of parts for it was at most a couple of bucks (can't tell you exactly since i used some parts from my chest of parts that have accumulated over the years)
  16. Tlyke1983
    Tlyke1983 Red Sonja
    70
    Wisconsin
    Ok well thanks for the directions but no. I do not trust myself to not muck it up to high heaven and then be stuck with a non-working Prius. So how much do you charge to come and do this? I'm willing to pay up to and maybe over 1 Chocolate Covered Cherry Cake and some Tollhouse Cookies. Can we work something out here? :)
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 20 2006, 12:05 PM) [snapback]335590[/snapback]</div>
  17. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(Tlyke1983 @ Oct 20 2006, 05:03 PM) [snapback]335853[/snapback]</div>
    Here are a few. :D
    * Free Reverse Beep Mod, *Raise Review Mirror Mod, * Aerodynamic hubcaps,
    * Almost Free Anytime Reverse Video, *Fumoto F103N Oil Drain Valve,
    *Almost Free Speed Wire Interrupt, *Almost Free Navigation Override switch,
    *Dual Microphone Mod,
    - Almost Free Anytime Fog Lamp, - Anytime Forward Video,
    - Inferred Fog Lamp Conversion, - Hydraulic Brake Pressure Indicator
  18. Tideland Prius
    16,159
    <div class='quotetop'>QUOTE(Cheap! @ Oct 20 2006, 03:25 PM) [snapback]335863[/snapback]</div>
    Just give him the link to the thread with the free or low-cost mods.
  19. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 20 2006, 06:27 PM) [snapback]335891[/snapback]</div>
    Most are here.
    http://evnut.com/prius_mods.htm
  20. GreenBeanMachine
    GreenBeanMachine New Member
    <div class='quotetop'>QUOTE(Tlyke1983 @ Oct 20 2006, 06:53 AM) [snapback]335292[/snapback]</div>
    In 06 JDM or right-hand drive model, the two slots are for EV (full electric mode) and Keyless entry disabling button. (for people who need to disble the RFID in case it interfere with their pacemakers). The manual headlight leveling swtich is relocated to the side of the Power button (which is below the right air-con vent)
