PANIC! Help!
Discussion in 'Prius v Technical Discussion' started by BartmanLA, Aug 12, 2018.
  1. BartmanLA
    BartmanLA Junior Member
    2015 Prius v wagon
    I just finished cleaning the Hybrid Battery Cooling system and in the process I felt to be safe I pulled the Hybrid Battery Power Interlock. And of course I put everything back together and reinserted the interlock plug all the way and slid it to the right to LOCK, but now I am getting a Hybrid System Malfunction message on my display. I didn't touch the battery itself at all, is there a "reset" I need to do or can do by myself? Or am I screwed and going to have to get a dealer to fix it? Any suggestions or hints please! I'm panicking here! Thanks in advance.
    49,371
    slide the switch after locking it down.
    if that isn't it, you probably disconnected a wire at the fan.
    Raytheeagle likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Not an uncommon occurrence.
    Apparently that interlock doesn't work exactly the way you would logically think.
    It's been discussed here a few times. Maybe a search for "interlock" would find it.
  4. priusb78
    priusb78 Member
    52
    46
    Nuremberg, Germany
    Have you tried starting the car a second time?
    Usually after working at the HV-battery and having it disconnected you get error messages on the display. Usually they disappear with the second trial.
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,917
    4,678
    Texas Hill Country
    She fixed by trying again but did not post the results here
    Brian Woodford and Raytheeagle like this.
