Parked for 10 days, lock us out. FAQ?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Hy-Dong, Feb 18, 2014.
  1. Hy-Dong
    Hy-Dong New Member
    3-week New owner of a 2014 PiP base. After coming back from a 10 day vacation, we are locked out of the car. The Toyota care service guy told my wife that this would happen if inactive for 2-3 days, which does not make sense to me at all. Is there a FAQ about this? Or we need to park it differently? We do not have a mechanical key to back up, so this is really unsettling.
    Many thanks!
    Dong
    49,359
    what? how did you get in the car? you have a metal key in the fob. you were locked out as in; the doors locked automatically, or, the battery died and the lock actuators don't work? the toyotacare person really told you that? are you pulling our legs???:p i left my pip for a month last winter, no issue at all.
    there is no FAQ because there is no answer.
  3. retired4999
    2,652
    625
    Eau Claire, Wi.
    Is there not a mechanical key in side your fob? Should be if not see dealer.
  4. CharlesH
    2,785
    1,152
    Roseville, CA
    When you buy a car like the Prius which has remote door openers, the seller has to provide you with a mechanical key, as well as a remote fob. I bought a Highlander hybrid a bit back, and didn't discover that the seller (a dealer) hadn't included the mechanical key until we inadvertently left the system on overnight in auxiliary mode and killed the battery. The dealer was able to provide a key given the VIN.
    After some time interval (I don't recall what it is), the remote door opener electronics shuts down to preserve the (tiny) 12v auxiliary battery, requiring use of the key to open the door. That should "wake up" the system so the car can be started normally.
  5. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    My FOB has a Mechanical key ..Just puch the button on the left side and out it pops ...back part of the key is the part that has the hole for a keychain And look at the door handle you'll see where to insert it...ans walaa the door opens
    And also you may have inadvertently left the interior light on.. it happen to me and I killed the battery.. Read your manual on Keys and jump starting
  6. Hy-Dong
    Hy-Dong New Member
    Thanks. I will need to look at the FOB. I did not see a separate key and assumed there is no mechanical key.
    I will check the interior light as well --wife was driving it.
  7. retired4999
    2,652
    625
    Eau Claire, Wi.
  8. bisco
    49,359
    pleasure.
  9. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    If everything else fails... consult with the manual:ROFLMAO:
  10. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I've parked my car for a few weeks and had no issues getting back in...
  11. Ploni
    Ploni New Member
    16
    2014 Prius Plug-in
    I think we were all surprised the first time we saw a key inside our fob.
    I remember the first night home after buying my PiP, I couldn't believe there were 38 pages dedicated to explaining how to open, close and lock the doors. My last car, with a standard fob, covered that in maybe 4 or 5 pages.
    retired4999 likes this.
  12. bisco
    49,359
    one of the few things my salesman actually showed me 10 years ago.
  13. CharlesH
    2,785
    1,152
    Roseville, CA
    It's surprising about how detail they go into about the issues one can have with the lock/unlock process, and how to work around the problems.
    Ploni likes this.
  14. 3PriusMike
    2,963
    2,314
    Silicon Valley
    Which is probably conveniently stored, for easy access, in the glove box, in the locked car.
    Mike
