Parking Brake Actuation
Discussion in 'Gen 4 Prius Technical Discussion' started by SagradaFamilia, Apr 7, 2018.
  1. SagradaFamilia
    SagradaFamilia Junior Member
    U.S.A.
    2018 Prius
    Evening,
    Just a curiosity. How does the parking brake on a Gen4 Prius actuate? Does the pedal draw a cable? Which wheels are locked? Thanks
  2. ChapmanF
    15,622
    In all three earlier Prius generations, it pulls a cable acting on the rear wheels (a lever and strut between the brake shoes, gen 1 and gen 2, an interesting threaded cam arrangement inside the rear disc brake calipers, gen 3). Without knowing any more about gen 4 specifically, I'd assume it's similar to gen 3.
    If you sign in to techinfo.toyota.com, the most interesting manual to go exploring first is the one called New Car Features Manual, which explains all kinds of stuff like that, specifically for your model.
    Are you an architect? Or from Barcelona?
    -Chap
  3. Diemaster
    Diemaster Active Member
    290
    260
    so. cal
    yes a cable. at least on my prime. i see no reason why normal gen 4 prius should differ. i saw it when i opened the center console to take pics of the wireless charger.
  4. Elektroingenieur
    2,515
    3,259
    Three Touring
    Indeed; cables actuate the right rear and left rear brake calipers, which have automatic adjustment mechanisms.
    RCO and krmcg like this.
  5. SagradaFamilia
    U.S.A.
    2018 Prius
    Thank you all for the response!
    Chap...Just lucky enough to visit Barcelona and the stunning Sagrada Familia. (Sounds like you've been there.) Then we purchased a car colored "Barcelona Red". Both are fine works of engineering.
    krmcg and bisco like this.
