Parking Brake Fail to Engage/Slipping
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Canard, Jan 10, 2025.
  1. Canard
    Canard Member
    223
    Ontario, Canada
    2010 Gen3/425k km
    In cold weather/when the cabin is cold, the parking brake is reluctant to engage. Feels like maybe the teeth are smooth and the pawl is not grabbing. If I release very slowly I can get it to latch.
    This only occurs when the car cabin is cold. After a drive when it is warm it will engage normally.
    Any ideas?
  2. ChapmanF
    18,892
    Mine's the same way. The grease that lubricates the ratchet pawl is thicker when cold, and the pawl takes longer to drop into the teeth and hold the pedal down. Pressing the pedal down and holding it a little longer seems to do the trick.
    Canard likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,343
    5,395
    Pacific Northwest, USA
    All the posts I've read about emergency brake pedal turned out to be related to loose bolts. Probably not the case with this one, but that's what I'd look at first.
  4. Canard
    Canard Member
    223
    Ontario, Canada
    That makes perfect sense. Thanks!
