Parking brake, handbrake or footbrake at lights?
Discussion in 'Gen 3 Prius Main Forum' started by Risco, Mar 27, 2017.
  1. Risco
    Risco New Member
    United Kingdom
    Business Edition
    Never had an automatic before, let a alone a hybrid. How best to stop at traffic lights? Foot, parking or handbrake? I am using handbrake on hills naturally and when parked on a hill.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Foot.
    Risco likes this.
    51,961
    does gen 4 have hill start assist?
  4. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    If you have hill assist - press hard on the foot brake and you'll get two or three beeps and the traction control light will start flashing. Then you can ease up on the pressure on the foot brake. The brakes will stay engaged for 3 seconds (I think) after you take your foot all the way off the brake or until you press on the accelerator. That's for hills. Otherwise just the foot brake.
    Read up on regenerative braking. Lightly pressing on the brake pedal will turn the motors into generators and charge the main battery while slowing the car down, so the longer you start braking for a stop light with light brake pressure the better.
    Risco likes this.
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    One dramatic advantage of the foot brake is that it lights Brake Lights, so you get rear ended less often. Park and the parking brake do not, leading to whiplash.
    mmmodem, Risco and jerrymildred like this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Welcome to the forum! Foot brake is SOP on all trucks and cars I ever heard of. Jimbo ^ mentioned a huge reason. Also, it modulates easier. The emergency brake not only doesn't engage the brake lights, you have to press it a second time to release. No control at all. And that's not to mention the regeneration you'd throw away not using the foot brake.
    Risco likes this.
  7. Risco
    Risco New Member
    United Kingdom
    Business Edition
    Thanks guys, so how do I know if it has hill assist? Thanks for the welcome, I will probably be making a few posts over the next few days while I learn more about the car!
  8. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Press hard on the brake after coming to a stop on a hill. If it beeps and a light lights up, you activated hill start assist and the vehicle has it. Check your manual to look for info on hill start assist and how it says to activate it if equipped. How I described it worked on gen 3 Prius and the Prius v.
    Read through the manual in general, great info in it concerning the car. Then, after reading, its best to ask any questions you may further have. The manual may answer most for you.
  9. Tideland Prius
    16,559
    Foot (brake pedal). It's rare that the light is long enough that I'll shift into P or N and use the parking brake.
    WilDavis likes this.
  10. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …wot he ^^^^^ (Tideland Prius) ^^^^^ said! Also, I try and drive so that I use the brakes as little as possible, zoom, glide, glide, zoom, glide, glide, zoom, glide, glide, gliiiiiiiiiide… :);)
  11. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    Where is the hand brake on the Prius?
  12. Tideland Prius
    16,559
    It's foot-operated. It's located on the left side of the driver's footwell, above the footrest.
  13. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    One unmentioned reason to use the foot brake at a light is it de-activates "automatic transmission creep simulation" thus not wasting the tiny amount of energy that system uses.
  14. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    So does Park.
