Parking brake lock and low battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AngelK, Jun 21, 2022.
  1. AngelK
    AngelK Junior Member
    17
    Clarksville, TN
    So, I got the Red triangle and P lock malfunction, go on flat surface, etc.
    Turned the car off, tried to turn back on, wouldn't. Jumped it, it turned back on. Did the wire from fuse to blue wire, which reset the parking brake, and allowed me to put the car in gear. Red Triangle of death was still there.
    Next morning, triangle is gone, car functioning normally.
    When I check the diagnostics of the car by doing the info/headlights x3 thing, it shows 11.8-12 volts, yesterday on the lower end, today it's staying at 12 or 12.1v.
    Then when I press power button again to put a load on it, it goes down to 11.8-11.9.
    When I turn the car on, it goes to 14.7-14.8.
    Is anyone able to help me diagnose this, because I have no idea what I'm doing. Should I put in a new battery, or is this some kind of issue with a hidden draw on the 12v battery happening?
    This thread says with the car on, it shouldn't go above 14.4 or there's an issue.
    There is a problem with the transmission 'P' lock mechanism...... | PriusChat
    49,429
    you need a new battery, how old is it?
  3. AngelK
    17
    Clarksville, TN
    Only 2 years old, and it's an Optima. So if you're saying I need a new battery, leads me to believe I've got a drain of some kind happening. Lame.
    49,429
    you never know. try charging it up and measuring overnight drop, connected and disconnected. what is the warranty?
    and how much are you driving? covid has killed a lot of 12 volts
    SFO likes this.
