parking brake not working
Discussion in 'Gen 2 Prius Main Forum' started by chaircatmeow, Feb 26, 2017.
  1. chaircatmeow
    chaircatmeow Junior Member
    california
    My 06 Prius parking brake is not working properly.
    After engaging the brake, I put the gear box in D or R without pushing gas pedal. Car is still moving.
    How can I fix it?
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    How does the parking brake pedal feel when pushing it? How many klicks does it go down with normal force? If it’s more than 9, start by checking that rear brakes look normal and are in adjustment. Probably the problem is in the back brakes. If there’s nothing wrong in the back brakes and cables are not sticking then there’s adjustment under center console.
  3. Stevewoods
    Stevewoods Senior Member
    648
    993
    Seattle, WA
    I adjusted the cable only, through the console inside the actual car. It did not do much. Apparently, you have to adjust at the rear brake drum to do it right.
    One of these days, I will either attempt that myself or pay my mechanic to do it. Having said that, I don't park on slopes. :whistle:
    Adjusting Parking Brake | PriusChat
