Parking button
Discussion in 'Gen 4 Prius Main Forum' started by hybrid hugger, Jan 20, 2017.
  1. hybrid hugger
    hybrid hugger Junior Member
    27
    2016 Prius Four
    I noticed that my right knee is perilously close to the Park button. Not that I would intentionally press it but I have a sorta morbid curiosity.
    What would happen if the button is pressed when the vehicle is in motion?
    Thanks
  2. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I believe it might ask you to hit it again if it is an emergency but I wondered the same thing myself as my knee could potentially but unlikely hit the button.
    RCO likes this.
  3. Mendel Leisk
    41,860
    Above a certain speed it won't put it in Park. I forget exactly, but it either ignores you, or puts it in Neutral. I think ignore.
    At very low speed, walking speed or thereabout, it will put you in park, with a bit of a jolt.
    RCO and robsnyder20 like this.
  4. Absolu22
    Absolu22 Junior Member
    28
    61
    Funny enough, I ask myself the same question if I were to be distracted while driving, what would happen! Anyone tried it?
  5. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    As Mendel said, don't do it at low speed (e.g. in a parking lot) because if you're going slow enough it WILL try to lock the transaxle and possibly cause damage to the vehicle like shearing the parking prawl (pin).
    If you do it while cruising at normal street speeds, it will only put you in neutral with a warning beep. Same goes for throwing it into reverse.
  6. hybrid hugger
    27
    Yup I just tried it at 10 mph and it put it in N with a message on the MID "shifted to N, stop to shift to P". Pretty smart!
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You are braver than I am, hh!
    But thank you for the info. regardless.(y):)
  8. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Yes, if above about 5 MPH it will go to neutral. If below it will engage the parking lock mechanism. It is not a "pin", it's a gear assembly and it's quite rugged. Unlikely to break from this accidental application, but don't tempt fate. ;) Oh, and if you do manage to engage it while moving slowly you won't want to do it again, it's quite disturbing for the occupants of the car. Been there, done that (by accident), don't want to do it again.
    alanclarkeau, RCO and Prodigyplace like this.
  9. Priifan
    Priifan Member
    93
    143
    Cary, NC
    Yikes! Doesn't sound like much fun! Glad that YOU did it! Ranks right up there with driving your first new Prius and forgetting to turn it off when you leave the car. Managed to slowly roll about a foot into a huge light post in a parking lot...TWICE! Fortunately there was a thick pad around the bottom of the light post because there was no damage to our car, just to my ego. And you could see that many others had tried this maneuver. (Fortunately Hubby was not with me either time.) Now I RARELY leave the car without turning it off after 5 years of driving Prii. The crazy things we Prius drivers do! Someone could write a book...
    RCO likes this.
  10. chughes123
    chughes123 Junior Member
    66
    vancouver washington
    FYI, if you shift from R to D or D to R while it is going in the opposite direction .. at low speeds, say a couple MPH, it will do it! Car doesn't complain, the electric motor sounds a bit stressed but whatever.
    Press on the accelerator when you shift to D when you are reversing slowly, that electric motor provides quite a bit of torque with the engine off. Close to slipping the wheels.
  11. Tideland Prius
    16,610
    Note that the above ^ may differ for folks with Intelligent Clearance Sonar (which includes drive-force reduction assist or something like that)
    kithmo and RCO like this.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I know the ICS and the automatic braking will prevent the car running slowly into something, as I found out when trying to get almost touching close to our plastic trash can.
    But what happens if the driver doesn't respond when the car stops itself ?
    Does it hold the brakes on indefinitely or does it release them after a while ?
    RCO likes this.
  13. Tideland Prius
    16,610
    It will release them after.... 2 or 3 seconds. The car will then just creep forward.
    RCO and kithmo like this.
