Parking for 3 months
Discussion in 'Gen 2 Prius Main Forum' started by hormosapiens, Mar 24, 2017.
  1. hormosapiens
    hormosapiens Junior Member
    44
    north Jersey
    Hello,
    I am parking my 2004 with 96k miles for about 3 months as I am going to work in SF. I am planning to find a covered garage/space but this is my first time and if anyone has any ideas where to safely park for cheap ( north Jersey), you are welcomed.
    Besides, is there anything I should prepare my Prius for these 3 long months?
    Thank you all for suggestions and ideas.
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    Why not drive the Prius over to SF and use it there?
    If you do decide to just park it, disconnect the negative on the 12v.
    hormosapiens and Mendel Leisk like this.
    49,488
    pump up the tires to max sidewall.
  4. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    What you NEED to do is mostly........nothing.
    Except for the 12 V battery. If you will have access to electrical power, a small battery tender/maintainer is best.
    If you won't have power, be sure the battery is fully charged and then disconnect the negative cable.
    IF.....the battery is over 5 years old, now would be a good time to replace it.....after you return.
    hormosapiens likes this.
  6. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Gen2 Prius as a minimum you need to turn off the Smart Key System (SKS) which on a Gen2 has a button under the steering wheel, if your model has the smart key (most do). Kevin in Denver probably covers this.
    I would get the HV battery reasonably full 6-7 bars before parking, and upon return home I would let the car warm up 5-mins without A/C before pulling out.
    m.wynn and JC91006 like this.
  7. JC91006
    16,482
    8,400
    If your hv battery is from 2004, I probably would not let it sit 3 months. That will pretty much kill it, the weak modules will go out of balance. Once a battery gets old, you have to constantly use it to keep it from getting weak and out of balance.
    m.wynn likes this.
  8. hormosapiens
    44
    north Jersey
    Actually, I am going to have a car company there.
  9. bisco
    49,488
    maybe get a prolong and balance before leaving?
  10. hormosapiens
    44
    north Jersey
    Thank you all for your replies. I will disconnect 12v battery and turn off Smart Key System. Is it difficult to disconnect the negative from the 12v battery? what tools do I need?
    Thank you.
  11. dolj
    dolj Senior Member
    7,653
    3,866
    Wellington, New Zealand
    If you are disconnecting the 12 V battery, you don't also need to turn the SKS off, as it will go off when you pull the power.
    No, it is not difficult to disconnect the 12 V battery, you will need a 10 mm wrench and I'd just remove the cable from the negative pole. Another alternative, is remove the red cover over the positive terminal and just unplug the white connectors from the black block attached the positive pole. You probably could do that with no tools, but a longish flat blade screwdriver would make removing the red cover a bit easier.
    The image above highlights the sense wire, you do not need to remove that one (won't hurt if you do), but if you look to the right there is another plug, you remove that one.
    #11 dolj, Mar 25, 2017
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,915
    Columbia, SC
    And, IIRC, be prepared to crawl into the trunk from the rear seat when you get back in order to reconnect the battery. The trunk won't open without the 12v battery being hooked up...
  13. CooCooCaChoo
    901
    504
    Cow-lee-fornia
    2023 Prius
    ^^^ Yeah that right there is gonna be the PITA. Although you could prep it by removing all the interior pieces aside for easier access for when you get back.
  14. dolj
    dolj Senior Member
    7,653
    3,866
    Another option, take a 12 V source with you to the car and connect it to the jump point under the hood. One of the those compact li-Ion starters, a regular jump pack or just another 12 V battery.
    JC91006 likes this.
  15. Sam Spade
    2,036
    1,023
    2017 Prius c
    Now that's an interesting idea.
    Just need to be absolutely sure that the clamps won't short out to anything.......including the hood when it's closed.
  16. dolj
    dolj Senior Member
    7,653
    3,866
    Why would you close the hood? As soon as you've opened the hatch, you can remove the power source.
  17. Sam Spade
    2,036
    1,023
    2017 Prius c
    WHAT ??
    We were talking about connecting a charger to the jump points UNDER THE HOOD......and leaving it connected there for a long time.
    I for one wouldn't feel comfortable leaving the hood standing wide open like that.......unless maybe it is in a locked garage at home.
  18. JC91006
    16,482
    8,400
    I think the idea is to have another 12v sitting in the car (or somewhere you can have access), then use that 12v to connect to the jump points to give you power to open the hatch. Then connect the disconnected 12v battery back
  19. Sam Spade
    2,036
    1,023
    2017 Prius c
    I can see that now after re-reading it.
    But that wasn't really specified in his post.........and that is why a small quote is ALWAYS a good idea.
  20. dolj
    dolj Senior Member
    7,653
    3,866
    Yes and no.
    You might have been talking about that, but I was responding to the discussion in these posts:
    My post just offered an alternative solution to having to crawl in the back to operate the manual release.
    However, your train of thought is an option too, as long as there is a secure location to store the car with the hood up.
