parking gear not engaging
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Ranchoz, Aug 20, 2021.
  1. Ranchoz
    Ranchoz Junior Member
    North Carolina
    2012 Aqua
    vehicle - toyota aqua 2012
    shift lever can move to the P position. however, P gear not engaging. as a result, car unable to switch on the engine. no any fault codes. once the shift lever moved to the P position, i was able to switch off the vehicle last time(however P gear not engaged) please advise
    49,498
    is that imported?
  3. Ranchoz
    North Carolina
    2012 Aqua
    yes
    49,498
    have you load tested the 12 volt battery? the pawl runs on an electric motor
  5. Ranchoz
    North Carolina
    2012 Aqua
    thanks for helping. it was faulty gear shift control cable. replaced it and now working properly
