parking sensor
Discussion in 'Prime Accessories and Modifications' started by eveyo, Mar 13, 2020.
  1. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    Hey guys. I have a 2019 prius prime premium. I wish I got the advanced for the parking sensors. Do you guys have recommendations on good parking sensors I can install? I like the concept of the fen sense wireless plate sensor but I see lots of bad reviews.
  2. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    is it possible to install toyota prime parking sensors on a 2019 prime premium? I know its on the limited or advanced. Is there some sort of software limitation?
  3. Salamander_King
    Salamander_King Senior Member
    11,010
    8,940
    New England
    Anything is possible, but is it plausible? Probably not. In order to install the parking sensors you have to replace both front and rear bumper covers, and you will need correct harness to connect the sensors to ECU, then you must be able to program ECU to be able to use it. All in all, you are talking extremely difficult and costly modification that will make buying a new Limited trim cheaper and easier.
    Tips and pghyndman like this.
