part # for the small panels next to dimmer
Discussion in 'Gen 2 Prius Accessories & Modifications' started by whiterice42019, Jun 3, 2009.
  1. whiterice42019
    whiterice42019 New Member
    Does anyone know what the part # is for the small pop out panels that are next to the dimmer? There are 3 of them 1 is for the dimmer one is for the HID and not sure of the other. I am looking for the panel that is by itself and not the switch. if that makes any sense lol. So to summerize its the location of where the dimmer is. I need the part # for one of the pop out panels. thanks in advance.
  2. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    I can't help you with the part number, but have you considered cruising down to the local junkyard? They might let go of something like that for cheap.
  3. whiterice42019
    good idea. never went to a junk yard before for parts.
  4. sl7vk
    sl7vk Member
    518
    22
    Salt Lake City
    My question would be... why?
    If you are missing one.... for whatever reason.... I'd install an EV switch, and use the missing panel to replace the one you need..... Or if that one is already missing, there's your solution...
    That probably didn't make sense.... so the long and the short of it, install an EV button mod....
  5. whiterice42019
    Where can i find an EV button less than 15 bucks?
  6. patsparks
    10,664
    564
    Adelaide South Australia
    Silence and tumble weed rolls across the street.
Loading...
