Part help- 2012 Prius plug in.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by surpriuse1, Oct 15, 2022.
  1. surpriuse1
    surpriuse1 New Member
    Los Angles
    I can’t identify this interior part and have been looking for hours. Does anyone know what it is?
    It is the vent cover next to the dashboard, not sure what the part number is.
    #1 surpriuse1, Oct 15, 2022
  2. Elektroingenieur
    2,515
    3,285
    Three Touring
    It’s the front pillar garnish corner piece LH, shown with part name code 62219 in catalog Figure 64-01, Inside Trim Board & Door Opening Trim Moulding.
    The part number depends on the grade, which you can determine from the model code on the certification label inside the left front door. If it’s ZVW35L-BHXBBA or ZVW35L-BHXEBA, the part number is 62219-47040-B1; if it’s ZVW35L-BHXGBA or ZVW35L-BHXEBK, the part number is 62219-47051-B0.
    surpriuse1 likes this.
  3. surpriuse1
    Los Angles
    Thank you so so much! I really appreciate it!
    Elektroingenieur likes this.
