Partial vs Full Repaint of Bumper
Discussion in 'Gen 3 Prius Main Forum' started by 9aussie9, Sep 1, 2020.
  1. 9aussie9
    9aussie9 Junior Member
    Los Angeles
    first post here :)
    A friend scratched my front bumper on the curb while parking and offered to pay to fix it, since the bumper was just repainted a few months ago. It is a minor, but visible rash. So we went to a few reputable body shops to get a quote.
    - Some said it is only necessary to partially sand and repaint the bumper, but would they put a clear coat over the full bumper.
    - Some said they would partially paint and partially clear coat the affected area only.
    - Some said they had to paint and clear coat the entire bumper, otherwise it won't seamlessly look good.
    I am confused. Any suggestions? I have a black 3rd Gen Prius Four if it matters. Thanks!
  2. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    If they know what they're doing, and use the correct Prius color code, '- Some said they would partially paint and partially clear coat the affected area only.' should work just fine.
  3. Mendel Leisk
    40,583
    Partial paint, then "blending out", is best for hiding the new paint. They do full colour just at the repair, then dilute with clear, go a little further, repeat 2~3 times more, till they're shooting almost clear.
    That said, "bumpers" being plastic dreck, and damage prone, just doing nothing for a while would be worth consideration.
  4. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Since cost isn’t a concern, go for the most expensive repair which will be new clearcoat and paint.
  5. Ed Beaty
    334
    311
    Salt Lake City
    SURE, be a really good friend and make YOUR friend pay maximum freight!
  6. BZzap!
    BZzap! Senior Member
    1,607
    878
    Down low on the bumper the paint will be less of a problem with the color match. If it’s on a flat horizontal panel such as the door or 1/4 panel at the belt line the match will be more of a challenge.
  7. Mendel Leisk
    40,583
    If I need to get down on my knees to really see the scrapes, on plastic, I leave 'em be.
    tvpierce likes this.
  8. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    I look down and see the scrapes on my knees, and then forget all about my bumper! :LOL:
    Salamander_King and Mendel Leisk like this.
  9. Johnny Cakes
    Johnny Cakes Senior Member
    1,042
    775
    Virginia, USA
    Agreed. You may gain a perfect bumper but is that really something you want to do to a friend? Like Mendel Leisk implies, this is going to happen again, given the height of the Prius bumper and parking, so there comes a point where you just try to forget about it. Basically, sh*t happens.
  10. tvpierce
    tvpierce Senior Member
    951
    881
    Maine
    2013 Prius v wagon
    Note to self: Don't hang out with @Grit . :rolleyes:
  11. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    No worrrieS. If I leave a dent on a friend’s bumper, I want them to get top value for repair and or replacement.
    #11 Grit, Sep 3, 2020
