parting out 2005
Discussion in 'Gen 2 Prius Main Forum' started by nancytheprius, Aug 8, 2021.
  1. nancytheprius
    nancytheprius Active Member
    356
    152
    iowa
    Hi guys. would buying a 2005 prius with 290k miles for 1000 dollars be good to part out and make a profit? does not have a catalytic converter is the only known problem. Otherwise drives fine besides being loud. He claims the hybrid battery was replaced within the past 20k but he’s only had it for a few weeks, so I don’t really believe that. Basically would all the other parts make it worth it?
    49,543
    i can't think of anything anyone would want.
    if the engine doesn't burn too much oil, you could put in a $250. cat and sell it for $2,000.
  3. privilege
    privilege Active Member
    659
    169
    Birmingham
    I'm still looking for 2nd gen wheels
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,249
    5,949
    Columbia, SC
    It would be difficult and time consuming to part out a 2005 and make a reasonable profit without the OEM cats.
    There's always variables that can make it worth it. Are you buying it because you need a new battery and this one has a Toyota replacement? Maybe it has a Toyota replacement ABS pump assembly that you need? Maybe brand new tires?
    If the MFD is perfect, you can get about $150 for the basic low-def 4 button non-nav model, the high def models will get about 250-300.
    The 4 dash AC vents will get about $140 for the set if in perfect condition.
  5. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    So if it has a battery and otherwise drives, why wouldn’t you add an aftermarket cat for a couple of hundred dollars and sell it?
