Passenger airbag are lifted on dash
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LHam, Jul 18, 2015.
  1. LHam
    LHam Junior Member
    26
    Gainesville, FL
    I noticed today in my new to me 2007 that the dash is lifted a little where the airbag is on the passenger side. Should I be concerned? IMG_20150716_191551.jpg IMG_20150716_191542.jpg
    49,397
    it's probably just deformation of the dash material from heat. the previous owner must have parked directly in the sun a lot.
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    #3 Beachbummm, Jul 18, 2015
  4. JC91006
    16,478
    8,394
    I actually think this is caused by the spring from the upper glove box
    bisco, Patrick Wong and valde3 like this.
  5. Beachbummm
    1,160
    392
    interesting idea, never had mine apart to check and it is in the same location on both cars...
  6. JC91006
    16,478
    8,394
    Does your upper glove box flap open and stay up without issue?
  7. Beachbummm
    1,160
    392
    one yes, one no..i will press down on the budge and see if it stays open on its own
  8. Patrick Wong
    18,200
    6,472
    This is correct. It is possible to fix that by re-securing the end of the spring. My 2004 had the same issue with the bulge in the dash panel. After I fixed the spring, the bulge gradually disappeared as the plastic slowly resumed its original shape.
  9. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Looks exactly like mine when it had broken upper glovebox spring mount. Dash itself did get back to correct shape after parking it into direct sunlight for half a day. Here that required rare hot and sunny day (wouldn’t have worked this summer). But there probably any day is fine…
    I did the fix almost as on that video.
    N.J.PRIUS, Beachbummm, LHam and 2 others like this.
  10. JC91006
    16,478
    8,394
    Nice video! I'm tempted to fix this on my 2005 but I really never open the glove box. I guess I'll make it a project if I'm bored one day.
  11. LHam
    LHam Junior Member
    26
    Gainesville, FL
    Ok, I am back, upper glovebox doesnt stay open, so will be fixing that and the murderously hot Florida sun will fix the dash. Thank you again lovely people of PriusChat.
  12. Beachbummm
    1,160
    392
    great find, I think im going to use plastic wall anchors in the hole for more support, I think the spring tension will break the plastic again over time
  13. N.J.PRIUS
    N.J.PRIUS Member
    140
    50
    Fort Lee, NJ
    2013 Prius Plug-in
    My 2005 has the same issue, always wondered what was causing that. Will fix this as it has always bothered me!
    Thank-you for posting this!
    Cheers
