Passenger Airbag Off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2manycruisers, Oct 16, 2015.
  1. 2manycruisers
    2manycruisers Junior Member
    Maryland
    We have had a 2006 Prius for almost 2 years now. In the past few months the passenger airbag seemed to become intermittent where the light would say "Off" even with a passenger. More recently it stays that way all the time. Also, the seatbelt warning light does not come on with a passenger when this light says "Off." In my early searches, I found some references to problems with the wiring harness, so I fiddled under the seat. On two separate occasions I have unplugged and plugged in one of the connections and the airbag works. The first time, it only worked once. The second time, it worked for about a day. The first time, the car was off when I unplugged it. The second time, I foolishly did it while we were going down the interstate. When I plugged it back in, the red malfunction light came on. We turned the car off next time traffic stopped and it worked as it should when we turned it back on.
    Has anyone experienced this and do you have recommendations for what to do? I don't know if it might be the pin connectors, loose wires, or something else completely.
  2. Patrick Wong
    18,200
    6,492
    Since you already know that if you remove and reinsert a particular wiring harness connector, you can restore the proper operation of the passenger-side airbag, you've narrowed down the problem considerably. The problem is with the wiring to the switch in the passenger seat which tells the SRS ECU the seat is occupied. The concept is that if no one is in that seat, then the airbag will not fire in the event of a front-end collision, which will save ~$1K in repair costs.
    My recommendation is that you buy a can of electrical contact cleaner. When the car is IG-OFF and no one is sitting in the passenger seat, disconnect that wiring harness connector and spray both sides with the contact cleaner. After the cleaner spray has dried, reinsert the connector and see if that provides a permanent solution.
    If not, then look for a problem like a loose wire attached to a terminal in that wiring harness connector.
  3. 2manycruisers
    Maryland
    Good idea, I will try that since I already have that cleaner. I unplugged it and plugged it back in a couple times this weekend with no luck, so I'm not as confident I have the problem narrowed down now. It also seems like the red airbag light stays on a bit longer now when the car goes into ready mode than it used to. Or maybe I notice because I am worrying about it. It is the last light to go off, maybe by a full second or more.
  4. 2manycruisers
    Maryland
    Does the fact that both the airbag sensor and the seatbelt sensor are not detecting a passenger help narrow down the problem? I can't remember if the seatbelt sensor used to detect lightweight passengers that did not activate the airbag. Now the passenger seatbelt light never lights up, not even a test during startup like every other light on the dash.
    #4 2manycruisers, Nov 5, 2015
  5. 2manycruisers
    Maryland
    I'm wondering if the problem lies in the seatbelt switch. The seatbelt indicator never comes on and the airbag light always says off. As I understand it, the airbag light would just say "airbag" if it detected no passenger at all. I'm not sure how to test the switch--I assume the two wires would be a continuity check, but I have no continuity ign on or off and seatbelt buckled or not. I checked on the driver side and I have continuity when it is not buckled and no continuity when buckled. That would lead me to think that if the switch does not have continuity, the car would think the passenger belt is buckled and therefore should be checking to turn the airbag on or off. That partially aligns with the indicator light saying "off" but then it should change to "on" with a heavy passenger. But it doesn't do that.
  6. 2manycruisers
    Maryland
    Not a lot of help here, so hopefully this helps the next person. I didn't have the electronics or skills to confirm, so I took it to a local Toyota specialist (not the stealership) for diagnosis. They confirmed the OCS was fine, but the seatbelt buckle was faulty. I ordered a used one for $39 off ebay, had it two days later and installed it in a half hour.
    So to summarize the symptoms in my 2006, the dash light on the passenger side always said "Airbag Off" and the fasten seatbelt indicator next to that light never illuminated.
    Pretty much the same problem this person had.
    Passenger Air Bag stays "off" - need help | PriusChat
    Passenger airbag light always "off" position | PriusChat
  7. Donald R MacDonald
    Donald R MacDonald New Member
    I just found this. Thank you for the info. Which piece of the seatbelt did you need to buy? The dealer just quoted me $80 for the seatbelt peace and $190 for the labor........ this was after trying to charge me $130 to tell me what the issue was when I never OKed them to charge me anything I brought it in as the problem started after they did an oil change and changed the serpentine belt so I was wondering if it was connected.
