Passenger "Airbag Off"
Discussion in 'Newbie Forum' started by CWM, Oct 26, 2018.
  1. CWM
    CWM Junior Member
    CA
    Once in awhile the passenger Airbag Off will light for a few minutes or a few hours. What's up with this?
  2. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    If there is no passenger or excess weight (I forget the weight limit that turns the airbag on) in the passenger seat the Airbag Off light should remain lit.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    This.
    It is intended to defeat the air bag if a small child (or person) is in the passenger seat.
    If it does not light when NOTHING is in the passenger seat, that in and of itself is not a problem.
    Test with a child. Seems like I remember 40 pounds but that might not be right.
  4. RRxing
    2,519
    1,790
    NEPA
    But it COULD mean the airbag is active with nothing on the seat.
  5. sam spade 2
    7,035
    2,788
    2017 Prius c
    Which is not right but if there really is nothing on the seat, it won't hurt anything.......even if there IS a crash.
  6. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Exactly. Assuming this the same Prius (2010) that the OP talks about in another thread. Accident big enough to set off the drivers airbag would total the car, passenger airbag or not.
  7. RRxing
    2,519
    1,790
    NEPA
    But it should really be checked out in case there's a fault that prevents the airbag from actuating when a passenger is present. That's what I would do, anyway...
  8. sam spade 2
    7,035
    2,788
    2017 Prius c
    Absolutely. (y)
  9. ChapmanF
    15,473
    See the Repair Manual re: calibrating the Occupant Classification System.
    Start by making sure there isn't anything stashed in the car, behind or under the passenger seat maybe, that could be leaning or bearing against it. Has the seat been out for any reason?
    -Chap
