passenger center vent trim removal
Discussion in 'Gen 2 Prius Accessories & Modifications' started by carbon6, Nov 10, 2010.
  1. carbon6
    carbon6 Junior Member
    Beaveron, OR
    So, what's the trick to removing the vertical trim strip to the left of the passenger that covers the vent? I've read somewhere that it just pops off, but I don't want to break any clips, or ruin the trim!
    Thanks,
    Mike
  2. jdenenberg
    jdenenberg EE Professor
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If you go to:
    Plug In Hybrid Electric Vehicle PHEV
    There are instructions on how to disassemble your dashboard in the section on Multifunctional Display (MFD) repair or you can read the attached pdf.
    JeffD
  3. carbon6
    Beaveron, OR
    Well, I be darned. It does pop off. I used a pancake flipper, which worked well. Thanks for the info.
    Mike
