Passenger door lock issue help needed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Markee, Apr 30, 2016.
  1. Markee
    Markee Member
    334
    South Florida Broward County
    Had a small fender bender and just got my 2013 Gen4 back from body shop
    and noticed my passenger door is not opening with the smart lock when I touch the passenger side handle or when I double press the smart key
    I did go into setting and setup 4 door open but still not working
    Is there some other possible setting I'm missing ?
  2. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Depends on where the fender bended. Could just be a loose connection...
  3. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    Return it to the Body Shop and make them fix it. Regardless who is paying the bill, it's their job to repair the vehicle.
  4. JC91006
    16,827
    8,600
    If you can take off the door panel, check to see if all the wires are connected
    SM-N900P ?
  5. frodoz737
    4,719
    2,517
    33
    One could, but why? The repairs paid for are not complete.
  6. JC91006
    16,827
    8,600
    It only takes a few minutes, saves going to the shop and having to drop it off.
    SM-N900P ?
  7. frodoz737
    4,719
    2,517
    33
    Being a Mechanic, I am paid to fix...so I fix., but if I pay someone else to fix something, they fix it. ;)
    To each their own.
    Rebound likes this.
  8. Markee
    Markee Member
    334
    The repairs were done at what the insurance calls there Concierge or preferred body shop so it carries a life time warranty
    So having it fixed is not a problem just its annoying the place is not close so having to go back there and wait or drop the vehicle is a major hassle
    so i posted here hoping it was just setting some simple fix I missed
    #8 Markee, Apr 30, 2016
  9. JC91006
    16,827
    8,600
    I had a similar situation when my minivan went into the shop, they forgot to put back 3 bolts by the fender liner. Instead of driving 20 miles, I just bought 3 bolts online and installed them. Cost was about $5 but it would've been the same going 20 miles and back.
  10. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    It's really easy to pop off the door panel. You don't need any tools except a Philips. YouTube search for Prius speaker install should show you someone removing a door panel. Most likely, they didn't firmly reattach the wire connector near the door handle.
    Markee likes this.
  11. Markee
    Markee Member
    334
    I'll try that anything better then wasting my day bring the car back there and waiting around all day
    On second thought i don't think they had to take off the passenger door panel the damage was front bumper and passenger side front fender the passenger door was totally unaffected
    is there another plug in under the hood that maybe loose i could look for ?
    #11 Markee, May 1, 2016
  12. JC91006
    16,827
    8,600
    The wiring for the door plugs in on the kick panel on the passenger side. Maybe they had to move those wires when they replaced the fender? I would check that kick panel area first.
    Markee likes this.
  13. Markee
    Markee Member
    334
    When you say kick panel where exactly do you mean ?
  14. JC91006
    16,827
    8,600
    When you sit down on the passenger seat, it's the panel to the right of your right foot. It's just a cover that's covering all the wires for the door. The picture attached is the kick panel......of a mustang.
    http://1.cdn.lib.americanmuscle.com/files/simco-twin-gauge-pod-06.jpg
    Markee likes this.
