Passenger door only goes 1/2 down and door doesn't open with window down
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by terramir, Dec 26, 2015.
  1. terramir
    terramir Member
    318
    50
    Los Angeles
    Anyone know what's going on and how to fix it.
    terramir
    51,155
    just a guess, but it sounds like the window has gone off the rail, and is jamming against the door lock mechanism. you'll have to pull off the interior panel for a look see.
  3. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Try rebooting several times with Power button. Then try window switch from both positions. Could just be a electronic anomaly bu Bisco is correct it sounds mechanical.
  4. Andyprius1
    2,327
    859
    Cool CA
    Also I don't think it's a good idea to actuate window with door open, I also only actuate one window at a time.
    My personal hang up.
  5. terramir
    terramir Member
    318
    50
    Los Angeles
    I am not sure, I think it's the thing that is supposed to keep the doors open, another symptom the door doesn't stay open
  6. ChapmanF
    17,349
    I'm with bisco on this, just remove the interior trim and take a look.
    Has there been any work recently done on that door?
    -Chap
  7. bisco
    51,155
    the door opening stop is pretty far forward, and unlikely to be a cause. they typically wear out on cars as old as yours.
