Passenger had key, exits, No Key Detected flashes
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by aljudy, Apr 2, 2015.
  1. aljudy
    aljudy Junior Member
    17
    San Luis Obispo, CA
    2015 Prius Plug-in
    I wonder what happens in this case when passenger has the key and is dropped off. I know what happens right away, a NO KEY DETECTED flash got my attention and was able to get the key before the passenger was gone. Does anyone know what happens if one continues to drive in this mode?
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The car runs fine until you turn it off. Since you have no key, you can't restart it.
  3. thuwaragan
    thuwaragan Junior Member
    Boston, MA
    The car will continue to operate as normal (with the exception of the NO KEY DETECTED warning). However, after you turn off the car, you won't be able to start it again (or lock it for that matter).
  4. Aditya
    Aditya Junior Member
    LA, CA
    2014 Prius Plug-in
    I think you should be able to lock it from the buttons inside front seat. (Lock I understood as lock the car doors)
  5. bisco
    52,388
    if you reach in through the open window, hit lock, hit auto up and pull yur arm out quick? not sure if the window works after you shut the car down.
  6. fuzzy1
    10,603
    The Prius allow the windows to be operated for about 30-ish seconds after the car is shut down.
  7. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Nope, unless you crawl out the window. Once the door opens, the windows stop working.
  8. bisco
    52,388
    get out with the car on, shut the door, reach in and press the power button, then lift the window switch?
  9. thuwaragan
    Boston, MA
    That would work... but who in their right mind? .... :p
  10. bisco
    52,388
    exactly.
  11. mmmodem
    2,732
    1,703
    Bay Area, CA
    Now that's thinking with your head! What about the old hold the door handle up as you close the door? I used to do it on my Hondas. Never needed o so on the Prius though.
  12. Trollbait
    12,680
    Don't see why you couldn't lock it by the door button with the door open. The only time I couldn't lock the 2005 was when the SKS fob was still inside the car.
  13. bisco
    52,388
    i really have no idea.
  14. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    I got that on my Plugin. I replace the battery but that didn't help. If your cell phone is close to the key. It won't detect it. Sometime I hold it to the engine start and NO KEY DETECTED disappear. Hope that help
