passenger mirror
Discussion in 'Gen 3 Prius Accessories and Modifications' started by harptree, Jul 10, 2014.
  1. harptree
    harptree Junior Member
    Portland, OR
    I
    The housing on the right side mirror on my 2009 silver Prius is cracked (photo attached)
    I'm trying to find out:
    Is there's a sub-assembly that would be used to fix this, or do I need to get a whole new mirror assembly?
    If I need to get the whole assembly, how can I tell if a used one is heated or unheated? Mine is unheated, and I found a used one, but the seller doesn't know if it's heated or unheated. Can I tell from the connector, or is there additional wiring apart from the connector if it is a heated assembly?
    Thanks!
  2. JC91006
    16,827
    8,600
    The damage looks very minor, I think you should leave it as is. The mirrors are ALL heated from GenII Prius, has nothing to do with the housing.
