Passenger side headlamp a little foggy on 2011 Prius Three
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rcaban, Apr 2, 2014.
  1. rcaban
    rcaban Junior Member
    My passenger side headlamp is a Little foggy and it's not the outside. It appears to be from the inside. There's no condensation. The driver side headlamp on the other hand is crystal clear. My question is how can I clean the headlamp on the inside without having to buy a new headlamp assembly. I suspect that when I changed the lightbulb on the passenger side I did not seal it in all the way I noticed it was a little off. This may have caused the outside air to get inside and caused the foggy effect. Is it possible to remove the passenger side headlamp, yes I know, that side requires removing extra pieces. And if so, can the headlamp be cleaned on the inside. Thank you in advance for your help. I love my Prius.
    matt b. likes this.
  2. matt b.
    matt b. Member
    251
    60
    L.A.
    my mechanic says that they can clean it for $20 so try your local mechanic
  3. matt b.
    matt b. Member
    251
    60
    L.A.
    another idea would be to look it up on YouTube cause you can find everything there lol
    WilDavis likes this.
  4. rcaban
    Good idea Matt. So what you're saying is that the lenses can separate or be removed independently of the entire headlight assembly and I could clean the inside.
    iPhone ?
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    YouTube and toothpaste! (check it out!)
    DROID4 ?
  6. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Reading comprehension is a good thing. OP said it was the inside surface, not the outside surface, that was foggy. ;)
    OP, if you can remove the headlight housing, you can try heating it at a low temperature in your oven. If you remove all the bulbs from the housing before heating it, then the idea is to let the water vapor escape from the openings. Be careful not to melt your headlight housing though. Protect it from touching anything metal by placing it on an old towel.
    SCH-I535
  7. WilDavis
    2,493
    2,154
    49
    What you say is true, but I'm my experience most of the oxidation (for that's what the yellowing is) occurs on the pride of the lens... ;)
    DROID4 ?
  8. WilDavis
    2,493
    2,154
    49
    For "pride" read "outside"... (stoopid phone!!)
    DROID4 ?
