Passenger side wiper stopped working
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Fruityfun, Nov 27, 2019.
  1. Fruityfun
    Fruityfun Junior Member
    Mesa
    2013 Prius v wagon
    Passenger side winshield wiper doesnt work but driver's side does. Hadn't used for half a year or longer.
    Where should I start? the assembly for both wipers must all be run by one fuse so maybe part of the assembly? Can the assembly be fixed if an individual part has worn or often will I just need to replace the whole assembly if there is an issue?
    Thanks for your experience and insight
    2013 Prius V
    52,362
    maybe not connected properly, or stripped. you should be able to get parts. take the arm off and see if the serrated hub is turning
    if not, then you'll have to dive in below to see if the linkage is broken or disengaged
