passenger window switch
Discussion in 'Gen 2 Prius Technical Discussion' started by FBear, Nov 30, 2011.
  1. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    Is there an easily available, exploded view of the passenger door. I want to find out how easy or hard it will be to replace the front passenger window switch by myself, rather than use the Stealors service department at $135.00 per hour. I have tried the other remedies but it is definitely the switch as the passenger window goes up and down quite nicely using the drivers control. Thus eliminating the motor or fuse as the possible problem.
  2. Politburo
    Politburo Active Member
    971
    208
    Usually switches are easy to access. This illustration isn't great, but I think it's the best you can get for free. Otherwise you can get a subscription to the repair manual for a day.
    2009 34 Prius Parts - Conicelli Parts Center
