passive entry
Discussion in 'Prius v Accessories and Modifications' started by chuck112281, Jul 1, 2012.
  1. chuck112281
    chuck112281 New Member
    17
    On prius V, only the driver's door have passive entry. is there any mod to make the passenger side door and cargo door have that too? I used to have a Infiniti FX45 which you can unlock the doors, from the driver side, passenger side and cargo door...
    If we can mod it, will be great.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,977
    4,717
    Texas Hill Country
    You can only set it to open all doors when the drivers side unlocks. About 5 seconds to do it.
    runukraine said: ↑
    It's pretty easy. You just get close to the car and hold lock and unlock down for about 5 seconds on your key fob. After 5 seconds you will hear two beeps. Two beeps means that all the doors unlock now when you use the smart door. Three beeps means only the drivers side door opens.
    Read more: How to unlock all the doors automatically | PriusChat
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  4. chuck112281
    17
    i know i can set all the door unlock once the driver's door unlocked. what im trying to say is i can unlock door using passive entry method on the passenger door and on trunk door. so i don't have to walk around to the driver door to use passive entry
  5. chuck112281
    17
  6. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    According to Toyota's specs on the V (check the Interior section) the three-door smart key feature is only on the Five. If the V is built the same way as the liftback, I imagine that to install this on lower trims you'd have to add all the components listed in the thread that cwerdna mentioned above - looks like a lot of work.
  7. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Well, the liftback's components may not work. There might be different parts and procedures needed on the v, if it's even possible.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The Prius v has three-door SKS like you want, but only on the more expensive packages. You should have opted up a bit if that was important to you.
    Tom
  9. chuck112281
    17
    didn't know they have that in the Five model. well all too late now. thanks for the info guys
