PCD Change
Discussion in 'Prius v Accessories and Modifications' started by lovetezza, Oct 31, 2021.
  1. lovetezza
    lovetezza New Member
    japan
    2013 Prius Plug-in
    I am English and Japanese.beginner on this site.
    I want to set the wheel of ZVW35 to 114.3.
    However, the Prius V cannot use 15 inches.
    Therefore, I would like to replace only the hub bearing with 114.3.
    If you know how to do it, please let me know.
    Some people do this in Japan.
    But they don't teach. why?
  2. vvillovv
    vvillovv Senior Member
    3,747
    1,320
    NY
    PCD ?
    There is probably a good reason why they don't tell why they change from 100x5 to 114.3x5 or 114.3x4 .
    Not for nothin, but it really doesn't sound like something I'd want to do, unless I had a REALLY good reason to buy 4 new hubs and 4 new rotors of the CORRECT size(s).
  3. lovetezza
    japan
    2013 Prius Plug-in
    I want to change from 100x5 to 114.3x5.
    To put on Skyline wheels.
    Replace the rear with a Prius V hub.
    What car hub should I replace the front with?
  4. vvillovv
    3,747
    1,320
    NY
    I'm not following!
    What does PCD stand for?
    Is the Prius V hub your planning to use for the rears a 114.3x5 mounting configuration?
  5. lovetezza
    japan
    2013 Prius Plug-in
    PCD is Pitch Circle Diameter. JP
    114.3x5 100x5.US
    プリウスVハブ装着時のリヤハブは114.3x5。
  6. vvillovv
    3,747
    1,320
    NY
