PCS Light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GAM, Nov 27, 2009.
  1. GAM
    GAM Australian Prius Owner
    Australia
    Hi All,
    First post, but I felt compelled to write this as I have been googling and no-one seems to have had this problem.
    Let me start by saying I am in Australia, so I am not sure whether overseas models have the same setup (we put the steering wheel on the other side to most of you guys).
    However, I have had issues with the PCS light coming on intermittently.
    Asked the dealer who had no idea, even when I took it in while the light was on. They returned it saying no fault found, no fault codes. I was assured it was a fault light.
    Anyway, to cut a long story short, I found that there is a Pre-Collision System override switch located just above the brake pedal. It seems that on a few occassions I have managed to bump the switch with my foot as it is immediately about the brake pedal with a basic "push-on / push-off" switch.
    It is likely to be more of an issue with womens pointed toe shoes ........not that I was wearing those :)
    But.....to me it is a bit of a design flaw. Very easy to turn off your pre-collision safety system by accident and then have no added benefit when you plough in to a wall.
    I will be making a cover to stick over it for future.
    GAM
  2. GAM
    Australia
    Do all regions have this button or is it a local (Australian) thing?
  3. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    Only the models equipped with the DRCC (Dynamic Radar Cruise Control) have the PCS (Pre-Collision System), because the Radar is the heart of the system, that being said, the U.S. Prius's are broken up into models, beginning with the II, and progressing to the III, IV and finally to the V. Each model can have packages that can be included with that model. For example, the only way to obtain the PCS, in a U.S. model, is to purchase the model V and have it equipped with the Advanced Technology Package, which includes: DRCC, LKA (Lane Keep Assist), PCS and IPA (Intelligent Park Assist). This is not based on Regions, just on which model you want, and how you want it equipped.
    The switch (on U.S. models) to deactivate the PCS, is located under the dashboard in-line with the steering column, nowhere near the footpedlas.
    David (aka Blind Guy)
  4. Tideland Prius
    16,128
    You're not really turning it off. You're only turning off the PCS Braking System. The seatbelts will still tighten and the system will still warning you with a BRAKE! message.
  5. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    I did the same thing, thought it was broken. Then remembered I had just reset the TPMS (tire pressure monitor system) and the buttons were close together, I had pushed the PCS while fumbling for the TPMS button.
  6. Tideland Prius
    16,128
    oh crap. I need to reset the TPMS. I bumped my pressures up to 42/40 on Nokian Rs but forgot to reset the TPMS.
  7. lloydb
    lloydb New Member
    Sydney, Australia
    GAM,
    You little ripper! Thanks a lot for that. My PCS light came on today and I didn't know what to do about it.
    I am taking the car in for a service tomorrow and was going to tell them about it then.
    I found your post, and tried your trick and it worked! Thankyou :)
    I never knew this button was there!
    Thanks again for your contribution!
    Cheers,
    Lloyd. :)
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  9. Katie preston
    Katie preston New Member
    Az
    My PCS warning light comes on even when the PCS is turned off? Help? Codes have come back clear i don’t know why the warning light continues to come on
  10. bisco
    49,399
    have you spoken with a dealer?
  11. Katie preston
    Az
    Not since last time this happened which was last year and they had NO CLUE as to why this was happening. The only resolve they came up with was to reset my radar in the front by setting up cones etc to the tune of $700....i can’t believe there are other prius owners who are having this problem?
  12. bisco
    49,399
    did they check for trouble codes?
  13. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The PCS light will come on when you press in the PCS switch located under the dash beside the steering column. When you press that switch again the light will go out. Some people manage to press it accidentally. Pearl S' PCS light is on all the time because I choose not to allow the car to brake at bridge expansion joints (which it can do per the owners manual).
    To locate the switch purposely you have to almost put your head on the floor and look up (use a flashlight). There are two push button switches under there, one labeled TPMS and one labeled PCS.
  14. Katie preston
    Az
    It;s not the PCS light that;s on it’s the PCS warning light.......i know the switch well, and sadly even when the system is turned off the PCS warning light comes on.
  15. Katie preston
    Az
    Yes they did check for trouble codes everything came back fine
  16. bisco
    49,399
    have you called toyota customer service?
  17. Katie preston
    Az
    No but I’m taking into a mechanic this week frustrated
  18. Katie preston
    Az
    So, update, took it to the dealership and they diagnosed a problem with the ECU system they made an adjustment and it seemed to have worked until he NEXT DAY when sadly the light came back on.
    Now they are wanting to replace the ECU system to the tune of $1500.....ugh
    Anyone ever heard of this
  19. bisco
    49,399
    no, but i would just put up with it for that price, until you can find a cheaper solution.
  20. Katie preston
    Az
    They have offered to cover half of the cost but now the light hasn’t gone back on
    They said I have to fix it within the next two weeks or their offer doesn’t stand.....kindof annoying
