PCS question
Discussion in 'Gen 3 Prius Main Forum' started by Yiannifun, May 31, 2011.
  1. Yiannifun
    Yiannifun New Member
    Athens, Greece
    Just saw a video on youtube named "2010 prius pcs test".. I wonder, if you hit the breaks just when the beeping starts, will you stop in time or hit the object? I mean, it starts beeping before it automatically breaks..
    What if you break when you hear the beeping? Brake assist will also engage.. Will you make it?
  2. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    A few days ago, my pre-collision warning beeped and flashed when a car unexpectedly pulled in front of me from the side of the road. I didn't feel the brake pump up and still had sufficient time to avoid a crash. I believe there are a few thresholds for the pre-collision system and this must have been the least aggressive.
  3. Tideland Prius
    16,121
    Good question. I did pose the question to the OP who made the video but I didn't get a response. I'm wondering if the PCS warning is sufficient and early enough to avoid an impact.
  4. Thai
    Thai Prius Neophyte
    1,197
    89
    I welcome anyone to test out the threshold.... :D
  5. Yiannifun
    Athens, Greece
    Well, i promise, when my grandpha will get me the car and it arrives in octomber, i will post a video as well :-P
  6. Yiannifun
    Athens, Greece
    I dont understand.. After the beeping started, what did you do? Did you brake? Did the car brake?
  7. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    I don't have PCS, but my understanding is that once PCS activates, computer determined that the object ahead and your Prius will engage an unavoidable collision; i.e. brake boost goes to standby/ready, seatbelts tighten, etc. I think the "between the lines" emphasis is unavoidable. Sounds to me like you would have a collision. I don't think you could engage the brakes as fast as computer.
    If you engage the brakes just before the warning indicators, then I suppose you would avoid the collision since you did this before PCS activates.
    I suppose the PCS system program assumption is that your Prius and the object ahead maintain their current course of collision. If the other object/vehicle veers, speeds up or alters course, then maybe collision is avoided.
    This safety option sounds very practical.
  8. Chris2128
    Chris2128 New Member
    85
    Oklahoma
  9. Yiannifun
    Athens, Greece
    I dont think so. Prius models equiped with PCS, also have Brake Assist system. When the radar senses an object coming towards you at a certain rate or faster, it places Brake Assist in standby and awates for your response. If you push the brake pedal, it assists you with exacly the right ammount of braking force needed, no matter how hard or fast you dipress the pedal. So i guess it depends on you whether you will crash or not. If you dont do anything, thats when PCS engages. But if you hear the buzzer and step on the break, brake assist engages.
    [ame=http://www.youtube.com/watch?v=W-pTakVadH4]YouTube - ‪2010 Toyota Prius: Pre Collision System‬‏[/ame]
    this video also mentions brake assist.
    I cant wait to get the car!! I will sure test it :p:D
  10. Chris2128
    85
    Oklahoma
    Dear op I disagree with what twittel "thought" how pcs works.
    I did a lot of my own research with my car (having pcs ofcourse)
    1. Pcs works in 3 stages. 1st one is warning, second is brake prep/optimization and 3rd is applying brakes and cinching the belts.
    2. Of all the experiments I did mentioned in the post link below, I could never reach stage 3 because it was too risky for me. I always ended applying brakes at the end because collision was obvious.
    The belts never cinched for me even when I applied brakes in these emergency situations. My last experiment scared the daylights out of me because the guy's car in front of me stopped and I was closing in on him at 23 mph. Only around 10 feet were left between us when pcs was already shouting loud. At that time i tapped the brakes and the tires screamed. If I had not nudged the car towards left, I would have hit the guy's car for sure. but I must say that the brakes performed 3 times more powerful than the force that I had tapped the brake with.(clearly proving to me that the pcs "primed" the brakes for me in less than a second !) also keep in mind that the tires on a v package are quite wide so that's like twice the stopping force compared to regular Prius tires. So my cars tires will never scream like Crazy but if I ever break that hard, I know I will only hear a light "slurrpp" kind of noise.
    Also in the video on YouTube with the cardboard boxes, the guy slammed twice in the boxes because the pcs did not provide enough brake force.
    So it's better for you to tap the brakes yourself if you wish to avoid collision.
    Here's a link to our old posts
    http://priuschat.com/forums/showthread.php?t=69375
  11. twittel
    1,605
    148
    Mt. Pleasant, SC
    Chris, thanks for the practical update on PCS. I'm almost hearing you say that PCS is not as responsive as I assume, but it still seems to be a great safety option.:)
    Though PCS is passive, does it work if dynamic radar cruise is turned off? I assume it does.
  12. Thai
    Thai Prius Neophyte
    1,197
    89
    PCS is on all the time. I think that there is a button buried underneath the dash that can turn it off. I guess that this OFF button is good for those who autocross. I have heard PCS activating when people do slalom testing and come close to cones.
    Stage 3 or whatever it is called of PCS is to decrease the severity of the accident, not to avoid it completely.
  13. mad-dog-one
    1,181
    420
    Whereabouts Unknown
    I braked aggressively as the other car accelerated away. One of the PCS features is to prepare (pump-up) the brakes for a panic stop. I did not encounter this increased braking action, which was unnecessary.
  14. Yiannifun
    Athens, Greece
    You were testing your pcs in real world traffic?:confused:
  15. chris1964
    chris1964 Junior Member
    San Diego
    I had my PCS activate for the first time this morning on my way into work. I commute on a pretty crowded road and it is a lot of stop and go. I was a little jet lagged this mornig and was not paying as much attention as I should have been. I believe I was going about 30 when I heard the warning beeps, instintively, I slammed on the brakes and I noticed that they seemed to engage really fast. I also realized that my seat belt cinched up for a second or two. Anyway, I did not hit the car in front of me but it was fairly close (5 to 7 feet?). I did hear the tires squeal a little as well during braking. Cruise control was off the whole time during this, so its good to know that PCS is paying attention all the time (even if I'm not!)
    Chris
  16. Yiannifun
    Athens, Greece
    Thats great :)
    Does it work only in cars or it can work for pedestrians too?
    Anybody that has experienced anything?
    In the video, the radar didnt sence the thin aluminium layer
  17. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    the problem with the aluminum foil is that they setup it up too high. It should be on the ground like the boxes.
  18. Yiannifun
    Athens, Greece
    No!! So thin items shoudnt ve recognisable..
    What if a plastic bag falls on your toyita emblim?!!!
  19. Yiannifun
    Athens, Greece
  20. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    so.. you saw the video with the foil? wasn't that one only with foil? there is one with boxes.. and a few others floating around. the guy with boxes holds the accelerator the entire time and the car almost stops him at the boxes. if he would have touched the brake, he would have stopped.. it was obvious on each run.
