PCS unavailable causing radar cruise unavailable
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Andreas121, Sep 27, 2021.
  1. Andreas121
    Andreas121 New Member
    Oh
    Two Eco
    Good evening,
    I recently purchased a used 2017 Prius with a cruise control that didn’t work. After some research I purchased a radar sensor and installed it. The cruise control worked great for about a month. Then stopped working again. Now again it says pre-collision system unavailable and the car crashing symbol is flashing. I’ve run the codes with no luck. Can vibration cause the radar sensor to stop working?
    I understand there is technically an alignment process, however I don’t believe this is the issue due to it working for a month.
    Any help is greatly appreciated!
    Thanks!
    49,358
    no idea, but possibly a wiring issue that is causing failure.
  3. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Welcome to PC! Just so you know that new members' first few posts are moderated, so don't be surprised if it takes a few hours for them to show up. I think it's the first five posts.
    On to your question! Perhaps a connection didn't fully click and has come apart? In the meantime, while DRCC is not working, regular cruise control might still work. Not sure about that, but I think it ought to since it works on cars that don't have radar.
  4. Andreas121
    Oh
    Two Eco
    DRCC will not work if the pre-collision system is unavailable. Is there a way to bypass the pre-collision system so that the DRCC would work as traditional cruise control. I’m still confused why the DRCC would work fine for a month then all of a sudden stop working.
  5. jerrymildred
    11,508
    14,109
    Tampa, FL
    Regular cruise control is simply a matter of long pressing the cruise control button as shown in the owners manual. I very rarely use DRCC. That's not really bypassing the PCS, but regular cruise control doesn't use radar, so it should still work. Not having had a radar failure, I can't say for sure.
