PCU coolant at low level
Discussion in 'Gen 4 Prius Technical Discussion' started by ykbj, Mar 6, 2019.
  1. ykbj
    ykbj Junior Member
    24
    2018 Prius
    Technology
    In light of the event of Engine coolant inside catalytic converter | PriusChat
    Is it normal that my PCU coolant is just right above/almost touching the low level line. My Prius is only at 17k km and it's less than a year old.
    Part #7
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    I think the dealership only fills it to the low level line at cold. If they were to fill it to the top, it would overflow when hot.
    So, as long as it isn't empty. Keep an eye on it.
    kithmo likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Mine is a tiny bit below FULL - but the engine is hot - I've only been home a little while after a ½hr drive.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    It should be between LOW when cold and FULL when hot, that's why it has two level indicators.
    If it's under LOW then it needs topping up (top up to Low level when the engine is cold), if it's over FULL then it is overfilled, if it's between then leave it alone.
    alanclarkeau likes this.
  5. alanclarkeau
    7,044
    7,584
    I've been out for most of the day - just looked up the manual:
  6. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    OK, but according to that, when the engine warms up, the coolant will be over the full level.:unsure:
  7. alanclarkeau
    7,044
    7,584
    Could be - but there is heaps of space above "FULL" for it to expand. Not sure if it expands as much as the engine coolant - you can touch the top of the inverter (just), you're not going to touch the engine when it's hot.
