PCU Volume Reduced by 33% for New Prius
Discussion in 'Gen 4 Prius Main Forum' started by usbseawolf2000, Oct 25, 2015.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Toyota Motor Corp disclosed the technique used to reduce the size of the power control unit (PCU) of the new (fourth-generation) Prius.
    The PCU is used to control the electric power of the hybrid system and equipped with an inverter for driving the motor, a step-down DC-DC converter, etc.
    The most distinguishing feature of the PCU is that its volume (8.2L) is about 67% that of the PCU of the third-generation Prius (12.6L). The small volume was realized by making improvements to the power device and cooling structure. Because of its smaller size, it can be installed right above the transaxle. As a result, it became possible to move the "12V battery" from the luggage space to the engine room.
    To reduce the volume, Toyota changed the cooling method for a card-like thin power module called "power card." The size of the power card was reduced by cooling the card from both sides to improve cooling performance and reducing the size of the IGBT chip (compared with the third-generation Prius). In the third-generation Prius, only one side of its power card is cooled.
    For the fourth-generation Prius, Toyota adopted a so-called "2-in-1" package equipped with the power elements of the high and low sides to eliminate the space necessary to install the power card. The company newly developed a package of the power card for the fourth-generation Prius.
    Toyota also reduced the loss of the IGBT. By reducing switching loss and steady loss, the company cut the power loss of the IGBT by about 20%, compared with the third-generation Prius. Though its withstand voltage is 1,200V, which is the same as in the case of the third-generation Prius. Its current density was improved by reducing the size of the chip.
    To reduce the volume of the PCU, Toyota reduced the number of control boards inside the PCU from two to one by adding various functions to the driver IC of the power device. Furthermore, the company reduced the sizes of the smoothing capacitor and reactor as well as the thickness of the DC-DC converter.
    PCU Volume Reduced by 33% for New Prius - Nikkei Technology Online
  2. godzillaismad
    godzillaismad Member
    199
    94
    Pretty impressive work... thinking forward with the use of Silicone Carbide in the coming years, with approx 80% reduction in semiconductor chip sizes, hopefully this would mean even smaller and more efficient PCU
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    Note that there is a huge difference between Silicone and silicon, despite the one letter difference in the word. This one is silicon.
    mozdzen and godzillaismad like this.
