PDA with mp3 player using Bluetooth on Prius
Discussion in 'Gen 2 Prius Audio and Electronics' started by mcitron, May 5, 2004.
  1. mcitron
    mcitron Junior Member
    26
    Sorry but I cannot seem to find if this question has been answered before, seems like a popular question:
    If I have an IPaq (or any PDA) with bluetooth, can I play music from the PDA through the car's stereo via a bluetooth connection?
    Seems simple, either it is possible or not. Has anyone accomplished this or know how to?
    Thanks
  2. aarons12
    aarons12 New Member
    704
    long island, NY
    i'm guessing probably not. bluetooth is basically a method of two things communicating with each other. but they two things in question have to be set up to exchange that particular data. bluetooth CAN be used for what you are asking, in theory, but the bluetooth in the prius is designed to received phone info, not mp3.
    for instance, it has been discussed that phones that have bluetooth just for headphones don't work with the prius, because THEIR bluetooth is only designed for the sound, not the numbers, phone book, etc.
    i use the si-link fm transmitter to listen to my nomad jukebox zen in the car. not a perfect solution, and other fm transmitters i tried hardly worked at all, but this one works for me...
  3. riskable
    riskable Junior Member
    74
    Jacksonville, FL
    The answer is no, but you probably wouldn't want to anyway... The Prius bluetooth implementatio only transmits audio to the front left speaker (mono).
