Peak full synthetic oil
Discussion in 'Gen 2 Prius Fuel Economy' started by theshark, Apr 27, 2011.
  1. theshark
    theshark Member
    164
    Martinsburg, WV
    Has anyone used this "peak motor oil? Can we use in a hybrid vehicle?
    Peak Lubricants - Motor Oils
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I use Pensoil Platinum because it is available for me in 0-20. Lots here use synthetic for various reasons . Do a search and read about all the reasons why. Peak is a good brand?Hal
  3. theshark
    theshark Member
    164
    Martinsburg, WV
    Hal,
    Thanks, I'v read where people use 0W-30 But 0-20? is the 2006 oil spec different from the 2007?
  4. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    0w20 is for Gen-III, and Gen II is 5w30? Check owners manual, you might be able to use it in winter.
  5. Hal W
    Hal W New Member
    872
    53
    I believe 0-20 is the desired oil to be used in Canada and has been for a year or so. Toyota came out with a directive on this matter for G2. I believe they have done the same in the US? 0-30 is OK . Hal
  6. Oldwolf
    Oldwolf Prius Enthusiast
    816
    107
    NC
    2016 Prius v wagon
    Hi Theshark. If you are going to consider synthetic, might as well use one of the big names. I use Mobil 1, but many others are worthy. Pennzoil, Castrol just to name a few. Check out Bobistheoilguy.com if you want more information.
  7. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    Hey I use 0w30 Amsoil and have had no issues. Wal mart sells 5 quart Mobil 1 0w/30 for 24.99 that would be your best bet. But all synthetics would be better than running dino oil.
