Pending P0016 code after head gasket replacement.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by johnnychimpo, Jan 24, 2021.
  1. johnnychimpo
    johnnychimpo Active Member
    514
    112
    Monterey
    I changed the head gasket I made sure I checked the timing is correct ( it is possible it is very worn chain car has f180k can the sensor be faulty or go bad? my fuel injectors were fine prior to this work and one went bad.
    the code is pending so not entirely sure what that means. the car is hesitant I understand that is due to retarded timing. any advice on how to proceed? I would hate tot take the timing chain cover off again but if that is what I need to to do then so be it.
  2. Mendel Leisk
    41,901
  3. johnnychimpo
    514
    112
    Monterey
    Found it. Now is this retarded or advance based on the position being off by one link.
  4. Mendel Leisk
    41,901
    I think the crankshaft normally turns clockwise (as you face the pulley on end of crankshaft). This is from my recollection of how Gasket Masters break the pulley hold-down bolt loose by cranking the engine with a wrench on the bolt head. So:
    If the timing chain is correct across the cam sprockets up top, but shifted counterclockwise by one tooth on the crankshaft sprocket, the valves will be opening and closing late??
    #4 Mendel Leisk, Jan 27, 2021
  5. ChapmanF
    18,543
    First question has to be: you have a photo showing the yellow crank link one position off, but was that photo taken at the same time you visually confirmed the two camshaft links are on their respective marks?
    Because the number of chain links probably isn't an exact multiple of the number of crank teeth, you'll be able to take photos showing the yellow crank link at various different positions on the crank sprocket. (If the number of links and the number of sprocket teeth are relatively prime, you'd be able to take photos showing the yellow link at every possible position of the crank sprocket.)
    So the only photo that matters is one that shows where the yellow crank link is at the same time the two cam links are in their correct position and nothing has been touched.
    Otherwise, just seeing the yellow crank link at the wrong spot on the crank sprocket at some random time doesn't tell you anything.
    If it really is mispositioned when the cam links are on position, maybe by removing the tensioner and slipping it off the exhaust sprocket, you'd be able to dangle the chain enough to pull it back up against the crank in proper position? I've never tried it, but I'd probably give it a pretty determined try before resigning myself to taking the whole cover off again.
